aftermarket steering wheel
Re: aftermarket steering wheel
you'll have to machine your own adapter, chop up the OEM wheel and weld the center hub to the new adapter plate. either way it's a lot of work.
May I suggest the Carlsson SL55 wheel, it has much better hand ergonomics,
I agree with you about the logo, but to be able to control the sound system, cruise, and other components would be worth it in covenience and safety. Maybe one of the members here could come up with a replacement pad for the airbag cover. Something Chrysler should have gave us when they designed the car.
on
Theres a steering wheel angle sensor in our wheels thats part of the stability control. If you replace it with a non-airbag wheel, the dash light comes on (and stays on). Theres also the turn signal clock spring that i dont think the 6004 has consideration for. The horn switch is an easy swap though.
