Size of Y pipe on Intake? (inches)
I am going to make a custom intake for my srt6, since I have not picked it up yet has anyone measured the size of the Y pipe that connects to the throttle body? Is it 3"? I need to know so I can order the correct connectors. Is it a 45 degree bend on that?
If anyone else has made their own, care to share what parts you used?
Thanks!
Thanks!
Re: Size of Y pipe on Intake? (inches)
Heres my photos of the y pipe when I was porting the intake, FYI. Hope that helps, its oval and I di not try to fit a pipe into it as I reused the stock piece,
The throttle body had a size about three that the Needswings connected to if that is what you were asking.
Originally Posted by skrzypekusmc
What part # is the Y pipe you were porting. I have an N/A and can only assume that's a stock piece from an SRT. I'm hoping to utilize it for a dual cold air set-up.
syfi
07-12-2015 06:59 PM
