Juiced...
Old 03-23-2008 | 04:43 PM
mrphotoman's Avatar
Default Re: Juiced...
can the srt6 handle a 100 shot safely with the boost on top of that? If so, that is IMPRESSIVE as hell. PLEASE PLEASE get some track times so we can see what that thing will do now!
Old 03-23-2008 | 05:12 PM
MUTT's Avatar
Originally Posted by MD SRT6
What are you using to monitor air fuel ratio's and exhaust gas temp's? And is it 100% at wide open throttle or proggressive.
Not monitoring at this point, i do have guages, i just havent decided where to install them yet...it is 100% open at WOT. The ny-trex system does have a regulator that will stop the flow of nitrous if the system leans out, so its a pretty safe set-up as it is.
Old 03-23-2008 | 05:14 PM
MUTT's Avatar
Hoping to make it to the track in April...there is a Viper truck meet up in the panhandle that i am going to crash...Hoping to whip up on some V-10's
Old 03-23-2008 | 05:51 PM
mrphotoman's Avatar
I hope to see some great vids at the track then!
Old 04-11-2008 | 02:20 PM
tylerxfire's Avatar
hey man im in the process of installing on my n/a but where did you put the nozzle to spray into the intake, any pics?, is it somewhere on the 90 degree elbow or past it or what, before after maf sensor, please pics would help me a ton. but an explanation will also do, also of where you tapped in for fuel for the nitrous, thanks
Old 04-11-2008 | 07:28 PM
MUTT's Avatar
i will take pics and post tomorrow for you
Old 04-11-2008 | 07:50 PM
tylerxfire's Avatar
awesome that would be great, where the nozzle should be mounted to spray and where i should put the t in the fuel line to get fuel, i have a zex wet kit gonna run a 75 shot. very easy set up i just want to make sure of where to do thes two things before i go cutting, i am just worried about where to mount the nozzle because of the maf sensoe and throttle body, but there is a ninety degree elbow before throttle body and puddling could occur if spraying into that, but yes i will def. go by your pics, you are having good luck with it?? any problems at all??
