F!@K these IC PUMPS!!!
Old 06-23-2008 | 06:13 AM
rodimus's Avatar
Default Re: F!@K these IC PUMPS!!!
Originally Posted by Montana Crossfire
The Johnson is the ONLY WAY TO GO !!!!!
I am still on warrenty but replaced with my own dime just so I could have the best.
I was told if you put the Johnson pump in. it voids the warranty.
Old 06-23-2008 | 09:13 AM
Voyager's Avatar
im curious as to how the dealership would know??? it is super far down the passenger side
Old 06-23-2008 | 09:31 AM
BLKFIN's Avatar
ADDICTED TO BOOST
I went ahead and changed to a Johnson Pump at 7,000 miles. My stock pump was working fine, but from what I read on the forum, it is not a matter of “if” the stock pump will fail but more like “when”. I wanted to change mine when I felt like it not when the car made me! It was a fairly easy install and well worth the piece of mind it brought me. I have only put 1,000 miles on the Johnson.
Old 06-23-2008 | 09:35 AM
SpaceManSpiff's Avatar
Default Re: F!@K these IC PUMPS!!!!!
Originally Posted by 1FASTC32
the pump is $125 shipped and the heat exchanger is $320 shipped...you can purchase both on our website here...
http://www.letmotorsports.com/chy.as...6&category=all
A little off topic, but what is the turnaround time on those heat exchangers? I ordered mine almost 3 weeks ago.
Old 06-23-2008 | 09:59 AM
Voyager's Avatar
holy crap thats a long time to go heat exchangerless
Old 06-23-2008 | 10:56 AM
radmanly's Avatar
Has anybody published an illustrated guide to changing your IC pump? Is this a do-it-yourself project or is it best left for the pros?
Old 06-23-2008 | 11:00 AM
rodimus's Avatar
I know I wouldn't be tackling this job. But I'm autotarded....
I asked my brother about this and he seems to think it would a very tedious task. He's not sure about the crossfire though.
Old 06-23-2008 | 01:35 PM
Im an autotard as well, but im learning. Probably the most important thing i've learned is to have a good set of tools, the right tools, and a nice place to work. From what ive seen, the ic pump doesnt seem like too hard of a job, But I didn't even know where the pump was located until a falling rock tore into my front bumper and made a hole right where the pump was. There are a few write ups on the site for both the pump and heat exchanger. Once my HE arrives I will be installing it along with the pump and I may do a detailed write up for dummies, with pictures.
This thread has many write-ups, including the IC Pump and HE.
https://www.crossfireforum.org/forum...ad.php?t=22326
Old 06-23-2008 | 01:48 PM
radmanly's Avatar
That would be great!
Old 06-23-2008 | 02:58 PM
Voyager's Avatar
the pump really isnt that bad. getting to it is probably the hardest part.
Old 06-23-2008 | 06:00 PM
GLHTurboSRT4's Avatar
Exclamation Re:Jhnsn IC pump electrical connector compatibility
Originally Posted by Steve Hellums
Does the Johnson pump come with the electrical connector that plugs into the SRT 6's OEM connector? I'm sure others would like to know this too. I'm still running my OEM pump with no problem's at 3,300 mile's, I'm asking the question because if it goes out I'd probably want to replace it with a Johnson pump.
Bump! I'm one of those "others." I'd like to know that too.
Thanks in advance.
Old 06-23-2008 | 06:17 PM
MikeR's Avatar
You have to take the connector off your IC pump and wire it to your Johnson. (pun intened).
MikeR
Old 07-01-2008 | 10:10 PM
Talking Re: F!@K these IC PUMPS!!!
MikeR
Thanks for clearing that up but it sounds painful... Good one.
Old 07-01-2008 | 10:38 PM
BrianBrave's Avatar
<--- Huge Horsepower
That's why I moved my Johnson - - so I could have easy access. I'll never have to drop the bumper or reach into a wheel well again.
Old 07-02-2008 | 05:12 AM
waldig's Avatar
Hey guys, How do you know that the pump is failing?
Serious, what is your indications? Does it not run and not pump??????
There are many causes that cause the S/C to shut off and NOSE DIVE.
The pump cools the intercooler and if the IAT is too high it will retard the motors power.
I am seriously wondering if the pump is the actual cause. I believe that there is more at work here and everyone may be suffering from Grays Antomy disease? I cant spell but it relates to beliving a preceived diagnosis because it fits the symptoms of the student in med school.
Lets get a data bank going for these pump failures and replacements to see what shakes out. Is this real or something else disguised as a pump.
Reason: every one that has pulled theirs reports that it was a good spare ( that I am aware of), Including me, when I THOUGHT THAT I HAD A PUMP PROBLEM. That is why I did the autopsy on my pump and posted it. Send me your old ones and Ill study them if you like.
Woody, Enjoy.
Old 07-03-2008 | 01:49 PM
Voyager's Avatar
well i know it was my pump because when the car slowed down to know other and i replaced the pump it was GREAT! but i also know that when i had the stock pump when the temp was all the way to the middle it would be slow but if it was low it would run fine
Old 07-03-2008 | 02:02 PM
waldig's Avatar
Well that is a bit of information, and I would love to get some of these pumps to study. I also want to inspect for film build-up on the impeller.
I have been fighting several issues with heat and the shutting down thing in addition to the throttle body sensor going bongo.
Enjoy, Woody
These colors presented by the 4th of July .
  #38 (permalink)
Old 07-04-2008 | 02:58 PM
HDDP's Avatar
The thing I find unusual is that the recirc pump from the NA Crossfire is exactly the same as the IC pump from the SC car and I have yet to hear of one failure of the recirc pump. Odd !
  #39 (permalink)
Old 07-04-2008 | 03:33 PM
BrianBrave's Avatar
My Limited didn't have an intercooler or a re-circulating pump.
Are you talking about the little cabin heater pump? - Two different pumps.
You have your N/A apart, could you take a picture and post the part number?
  #40 (permalink)
Old 07-05-2008 | 06:47 AM
HDDP's Avatar
Yes, the heater recirc pump Bosch PAA 12v part #0392020026 it has the same specs as the IC pump. Here's a photo alongside the Johnson.
Billy22Bob
09-28-2015 08:08 PM
Billy22Bob
09-26-2015 10:16 PM
Selbyl
09-26-2015 04:15 AM
tritongreen
09-18-2015 07:32 AM
81's
09-13-2015 04:34 PM
Quick Reply: F!@K these IC PUMPS!!!
