Meth injection
Re: Meth injection
Originally Posted by MUTT
Is anyone running a methanol injection set-up on their SRT? If so, what kit are you running?
https://www.crossfireforum.org/forum...ohol+injection
according to the pics he is using: alcohol injection systems product.
Re: Meth injection
Would this one Needswings sells work with our car? http://www.needswings.com/ProductDet...?productID=508
Re: Meth injection
Having one of these would seem like a good idea for people running the 185mm pulley since it is said to raise the temps. I think I might try that trunk mounted system from www.alcoholinjectionsystems.com once I get my pulley installed.
Re: Meth injection
Re: Meth injection
you could be really cheap and install a sealed 1 gallon plastic or stainless tank filled with Alcohol under the hood.
Run a pressure line from the Kompressor to the tank, then from the sealed tank to the throttle body. and install a mister nozzle from MC MAster Carr. DIY it for about $150
Re: Meth injection
i think i am going to stick to the system i ran on my Ram SRT-10...snow performance. Here's a link if it's allowed:
http://www.snowperformance.net/products.php?p_cat=195
Re: Meth injection
Re: Meth injection
Would it be possible with the way our cars are setup to add a injector nozzle into the supercharger inlet after the intercooler so that you could lower temps in the SC without puddling in the intercooler. And if you could, would it be advisable since I dont think fluid normally goes through the SC? Just curious as to how to use alcohol injection the best.
Wisconsinfdcrossfire
09-20-2015 10:04 PM
tritongreen
09-18-2015 07:32 AM
