Polished y-pipe with teflon coating
Old 02-10-2008, 04:27 PM
NeedsWings's Avatar
Default Polished y-pipe with teflon coating
we sent a couple of these off to the port/polish company we deal with. they polished the inside of the pipe and then had them teflon coated, these 2 are both already spoken for but i have more on order so we should have some extra cores to be able to turn them around for you guys if your interested. the teflon coating was tinted with a gunmetal color on these.
i forgot to snap pictures before we started but i'm sure there are some floating around on the board, i'll snap some when the other new ones arrive here.
after polishing...
after teflon thermal coating...
by the way, the shavings did not burn like normal magnesium, they must be an alloy mixture were assuming.
Old 02-10-2008, 04:30 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Polished y-pipe with teflon coating
looks to be a very nice quality piece!!!
nice work!
Old 02-10-2008, 04:47 PM
NeedsWings's Avatar
"looks to be a very nice quality piece!!!" thank you
Old 02-10-2008, 05:27 PM
jonnyangel04's Avatar
Beautiful, I guess I will be the first to ask what if any gain does porting and polishing, along with coating them do ??
Old 02-10-2008, 06:12 PM
ShawnQ's Avatar
And, Price?
Old 02-11-2008, 11:23 AM
BlUEMDsrt6's Avatar
This seems like it will go good with those upgraded intake manifolds your making.
Old 02-11-2008, 11:47 AM
240M3SRT's Avatar
Is the teflon coating supposed to serve as a thermal barrier? And as mentioned above, whats the price?
Old 02-11-2008, 12:42 PM
what is that y-pipe for?... It looks really nice...
Old 02-11-2008, 02:05 PM
240M3SRT's Avatar
its the stock srt-6 y-pipe feeding air from s/c up into the manifolds.
Old 02-11-2008, 02:58 PM
NeedsWings's Avatar
improved airflow
price is yet to be determined (gotta see how much the teflon coating will cost us as these 2 were samples)
Old 02-11-2008, 04:09 PM
NeedsWings's Avatar
absolutely
Old 02-11-2008, 08:16 PM
240M3SRT's Avatar
needswings, what is the point in the teflon coating?
Old 02-11-2008, 08:23 PM
NeedsWings's Avatar
it created a super slick surface on the inside of the tubing, even more so then the port/polish
Old 02-13-2008, 11:07 AM
SRT6_Roadster's Avatar
How much for the y-pipe?
Old 02-13-2008, 11:15 AM
Maxwell's Avatar
I'm no airodynamic engineer but did you know that a rough finished surface is more efficient for airflow than a smooth surface, mostly because of the surface tension of liquids adhears better to smooth parts than rough ones, you might want to sand the inside of the coatings off.
Old 02-13-2008, 11:20 AM
BlUEMDsrt6's Avatar
Originally Posted by Maxwell
I'm no airodynamic engineer....
Your also not much of a speller.
Old 02-13-2008, 11:26 AM
Maxwell's Avatar
just posting facts, and for my second attempt, "aerodynamic" better?
Old 02-13-2008, 01:56 PM
NeedsWings's Avatar
there is no liquid going thru these tubes, for the intake manifold runners yes i agree but this piece is way before fuel gets sprayed
Old 02-13-2008, 02:28 PM
Maxwell's Avatar
air acts very similar to liquids it's velocity is measured in renolds numbers just as with liquids, it's just not as dense. either way it seems a bit of an over kill. looks good though!
Old 02-13-2008, 07:24 PM
BlUEMDsrt6's Avatar
Leave it to Maxwell to be the nay sayer/ thorn in the side. LOL . I'll give you one thing Max, your consistent.
Quick Reply: Polished y-pipe with teflon coating
