SL 55 intake guys come in
Re: SL 55 intake guys come in
Originally Posted by roncosrt6
Steve, I see you added tubing to extend 'Y' to fit to airbox.
Does this allow you to place airbox in original stock SRT6 airbox
location? I read other thread that modifications had to
be made in the placement of SL55 air box? Installation by Brain.
https://www.crossfireforum.org/forum...ad.php?t=20009
i will post all my pictures of the installation.The onlly thing i had to do on the air boxes was make new mounting brackets.I had a problem going thru the opening on the drivers side of the radiator but steve gave me a tip on using two and a half inch id reinforced radiator hose which worked great.If i can answer any other questions on my install let me know. ILLCYA
Originally Posted by Steve Hellums
Yes it did, it was quite the wrestling match to get it together. the directions of what I done are on this thread - https://www.crossfireforum.org/forum/...ad.php?t=19780
Originally Posted by PA/XFIRE
Steve did you use the oem air boxes with the sl55 y fitting ? Just curious.ILLCYA
I installed the sl55 air boxes right on the ends of the y fitting and they fit great.As soon as i find a tutor to tell me how to post pictures on the forum
Originally Posted by ws6vert
Who did you get the sl55 boxes from and what did they csot?
Yes I used the OEM 3.2 air filter boxes, I don't think that the SL55 boxes match up with the engine cover and I wanted to keep the OEM look as much as I could.
on
Originally Posted by srt6_crossfire
I might have been the first one to put this on an SRT6. Got it with ecu+pullies+SL55 intake package from SpeedInnovation. Since I got it as a package, can't really tell you what difference it made on its own.
No issues. Will be taking it off though and replace with Needwings intake.
Originally Posted by SRT6nTulsa
What are your plans for the SL55 setup? I'd hate to see it go to waste....
Just thought I'd add my $0.02 to the thread, as I've just finished test
driving my SRT-6 after having installed the SL55 intake I got from LET.
Just my opinion, but I'd say I've added a whole lot of torque, and my
acceleration appears to have been positively affected. I can hear the
difference in the sound. Whereas previously when I planted my right
foot to the floor I'd hear the air intake make its whine, now it sounds
like there's a tornado under the hood. I really am impressed with the
apparent (perceived) gain this modification has added. It seems that
with more air, the engine has really come alive.
I would recommend this modification.
Coyote
Coyote
<--- Huge Horsepower
Coyote
Coyote
I'm getting close to requiring new filters for my SL55 intake and was considering the K&N's...
on
Brian, I got K&N's with my SL55 intake. I got it put on today except for the tubes. I didnt have the torx wrench to pull the bumper and get the boxes next to the radiator out of the way. I may take it out, as is, just to see how it feels. I'll finish up the tubes when I put the 181mm pulley in. I hope to get my replacemnt WP pulley by the end of the week. That would give me something to do next week end.
MikeR
MikeR
MikeR
MikeR
I was able to remove the intake feeds from the radiator support without removing the bumper. Just a little effort but no forcing was needed. BTW the brackets you fabbed up looked great...
BB
Did you install K&N filters at the same time you installed or intake or use the OEM filters that come with the airboxes?
them out for K&N's soon, but right now I want to get a good feel for how
different the SL55 intake is from the stock intake. BTW, thanks for your
write up, and for sending out the bracket pieces.
On that last, I've not yet received those in the mail, but I was able to come
to a solution when the pieces you were sending didn't arrive by Saturday's mail. It just so happened that I had a couple of mounting rails
from an old Compaq array I just received from a friend. These rails are
made of stainless steel and had a shallow, squared at the bottom, 'U'
shape. The width between the up-turned blades was just a very small
bit short than the attachment point/platform for the stock clips. So, after
trimming the rail material to about 2.5 inches, I gently hammered it on
to the clip platform (shaving a mere hair from each side as it went on) and
then screwed them in place. I then mouted the clips to the extended
mounting platform and did the same for the back end clip. Repeated
this for the driver side, and all attaches nicely on the clip connector *****
on the motor.
Took it for a test drive, and was posted earlier, was rather impressed with
the result. Thanks again for your write up and help.
Coyote
MikeR
MikeR
through boxes removed from the radiator support. If you remove the
top screws (one on either side) for the bumper, near where the boxes
have their screws, you can pull back enough on the top of the bumper to
be able to remove the boxes. Note that the boxes are pinned with push
pins to the radiator support. These pins need to be removed to pull the
boxes out. There is one on the outboard side of each box, that is a bit
of a pain to get to, but it can be done without removing the bumper.
Coyote
on
Okay, here are the some pics of the SL55 on my Aero ----->
I have them setting up a little higher from the manifold and it looks like I need to adjust the air tube on the driver side to level out that box.
I dont know if I will keep the cover on or not yet.
MikeR
MikeR
