LETMotorsports Now Carrying JOHNSON PUMPS!!! CM30!!!
Re: LETMotorsports Now Carrying JOHNSON PUMPS!!! CM30!!!
Jerry, the TYCO connectors are available thru a distributor I found in Los Angeles. Also you can cross match with a Delphi connector as well... Unfortunately, I am in New Orleans shooting a movie and do not have access to my database. If you do a little searching, you can get the parts very cheap...
MrPhotoman: I have pics of the pump located in my SRT6 Engine Transplant thread... Do a search...
According to Tyco, the part we need is not being sold anywhere. We need coding "C".
If you have this part or can get it, then do the forum a favor and post up where to buy it. It will save everyone money....as we were going to charge more than the connector and pins cost.
Maybe I am missing something here but what is so important with those connectors anyway? It is easy enough to splice the wires with another type of connector. I do not see that this would be a big problem. If I am not understanding somethig then perhaps someone would explain. Thanks.
If it were 'Plug -n- Play' it would be much more popular and easier to install, BUT, as far as AMG-Jerry goes, I can understand where he is coming from. Most of the customers who are upgrading pumps will have enough DIY knowledge to get it done, or enough $$ to pay someone to figure it out for them. They tried to do it as a courtesy but they are also trying to run a business. It got to the point where it was no longer cost effective...therefore they let it be.
I don't like hacking the stock harness, regardless of how good of a hack you do...
HDDP, I may do some searching tomorrow with the info you've provided and try to find the source you found.
SQ
SQ
SQ
SQ
Brain storm: couldn't we just hack the pump connectors? Take the connections from the old pump and put them on the new pump?
Originally Posted by cgocifer
Neither do I. I'll search too. If you find something, please let us know. I'll do the same.
I'll look into it more tomorrow if I get a chance during work.
o55ie18
10-05-2015 05:50 PM
Selbyl
09-26-2015 04:15 AM
tritongreen
09-18-2015 07:32 AM
