Aluminum Intake Manifolds for srt6
on
Re: Aluminum Intake Manifolds for srt6
i need to pull them back off the car so we can start the changes for the next set.
we havent broken anything yet on the car
other then the occassional one wheel peel durrign the burnout the drivetrain is holding up great, we just got in with quaife so ill have to see how close their c32 lsd is to fitting ours
Also waiting on the manifolds..
To bad you can't get a high-stall converter for the Merc auto. Maybe some smaller diameter rear tires would help.
Is the SRT's 3.07 differential any more "beefed up" than the NA's 3.27? If not, then swapping differentials with a Limited, and going down 1" in diameter with your Drag Radials would be almost like having a 3.50:1 gear. Would really need the LSD then.
on
One look that was powerful both for Visual impact and marketing through the 60's & 70's was, and we all had or wanted them, Mickey Thompson finned valve covers. That's a look, that would still look great and aid in the disipation of heat.
Mike
give me some ideas please, or we could just cut grooves in the top to give it a ribbed look. we have acess to waterjet/cnc/laser so limited by imagination basically.
[/sign][/sign]
[/QUOTE]
[/quote]
Mike
QUOTE]
[/sign][/sign]
[/QUOTE]
[/quote]
on
on
1 Post
Originally Posted by Chi-Town SRT/6
Rob,
Count me in on this mod...It would be nice to get my title back
rear diff...
we have a 3.07 gear back there, the c32 uses a different housing so the quaife will not go back there. the na xfire and slk 320 use the same housing as the srt6 with a 3.27 gear. im trying to get ahold of one of those to bring to getrag to see if they can beef up the springs to get us closer to equal distibution with it
on
1 Post
Originally Posted by BlUEMDsrt6
Hey Chi, read my sig. Your going to need alot more than that to get your title back. Theres going to be alot of nasty SRT6's once LET sends out those pulleys.
on
1 Post
Hopefully the rearend/gears and ECU aren't like the ones in the LX cars(charger/300/magnum) which use M-B rearend and tranny. For a long time it was impossible to change the gears because the ECU would see the difference in wheel speeds; among other things, and shut the car down. Supposedly they just solved that problem with the new Diablo programmer.
on
1 Post
