Koni Is The Answer
Old 11-24-2007 | 10:36 AM
SRT6 Dan's Avatar
Banned
Default Re: Koni Is The Answer
Originally Posted by eganders
I'm also anxious to hear about anyone's progress in this regard. On these forums I've read about swapping the springs from the SRT-6 for either the limited springs or the Eibachs - but at the same time, they weren't switching the shocks. Either way, the authors mentioned improvement, but they weren't jumping up and down about it.
If the other half of the change should be the shocks, whether Koni's or Bilsteins - whatever, I'd sure like to hear about it. I've read the same things on the forum about the "sports car ride", etc. So if it can be made a little easier on the bod it would be a welcome change.
Question: Who has changed BOTH their springs and shocks? What did you change from and to, and please tell us about the quality of the ride after doing so?
I think you need to do both shocks and springs! Also the Crossfire comes stock with bilstens. I have done rear springs to LTDs a little improvement.
Old 11-24-2007 | 10:41 AM
SRT6 Dan's Avatar
Banned
Originally Posted by crossbowme
There definitely less harsh. Before, when I went over tracks, etc., it would hit them like the shocks were welded down (BLAM). At the same time, I got a snapping motion that almost hurt your back.
You can still tell you're riding in a high performance car but the snapping motion is gone completely. It no longer feels like your smashing your way thru the tracks. In fact, (I am probably dreaming about this one) but it seems to me the car is more comfortable in all phases of driving.
That's probably because the konis are adjustable and low pressure shock. good to know it works for ride quality!!! Thanks.
Old 11-25-2007 | 01:12 PM
LantanaTX's Avatar
When I first trimmed the stock SRT springs it would ride like that in the rear. Then Dan told me about the bumpers in the rear shocks (I did not remove the shocks when doing the trim, just removed the bottom bolt).
I went back and swapped them both out with a set small black bumpers I had. This made ride way too soft with too much body roll when driving aggressive.
I then trimmed about a 1/3 off of the stock bumpers and re-installed. The ride now is perfect, not jarring, but not to soft. Plenty of give on RR tracks, dips and those California cement freeways.
I think it rides better now then when it was new.
It's a cheap alternative ($0.00) you can try before spending any money. Not sure if the limited has this bumper in the shock.
Stop by Dan and I'll take you for a spin.
Here is a pic - it's hard to see the black bumper on the rod but it's there.
I trimmed my bump stops today. The car rides very smooth and could almost use a firmer shock. I could tell that since I lowered my my car, I was hitting the bumps stops on bigger bumps. I am concerned when you said with the small bump stops the car was too soft. I wouldn't want the bump stops doing the job of the springs and shocks. My bump stops were exactly the same as the one in your picture. I cut mine just about in half and used the half that has the groove in it. I put the flat side against the body of the shock and tappered end pointing up. I think I will go with Bilstein's aftermarket HD shock in the future. Another thing that helps my ride is the lighter 18 inch wheels in the rear.
Old 11-26-2007 | 10:48 AM
SRT6 Dan's Avatar
Banned
I'm glad it worked for you. This is the main reason our cars ride so tight when lowered!
TerryR
12-13-2019 03:27 PM
jimf
10-10-2015 10:22 AM
2005 Ragtop
10-03-2015 03:01 PM
09-28-2015 07:40 PM
09-26-2015 10:21 PM
Quick Reply: Koni Is The Answer
