SRT6 Serial Numbers - Original thread closed
re: SRT6 Serial Numbers - Original thread closed
After checking the plate on the driver's door our car isn't very near the end!
Date: 06/05
MDH 060113
So i guess just one of many Maybe I should buy one of the '08's off the company lot, seen about 6 parked around there now. A red one was parked next to a SRT8 Challenger yesterday. WOW nice car, too bad they don't come in a soft top!
Date: 06/05
MDH 060113
Date: 06/05
MDH 060113
Date: 06/05
MDH 060113
Yours may be the next to last 2005 built according to Tom's/RPM's #s.
Probably # 92X or 93X, of the 938 built
(+/- the (12) 2006s built for Display/Review around the World)
This should do it:
Here's a pic of it's build plate.
This Black SRT6 Roadster was made the Same Hour (1200) as My New one & 3 SRT6's before, My # is 64172 (The Last SRT6 Roadster Made in the World, I Believe!)
Originally Posted by tom2112
Bill, you're too funny! Now I'm _REALLY_ curious. How did you get a pic of that car's build plate? Was it one of the ones you looked at buying?
It has been for Sale Forever (The last 6 months plus, on Autotrader, but that pic in not there....
Then is was on eBay for a week a few weeks ago & the Pic, was there.....
so I copied it to my 2006 Album, as "One of the Litter" so to speak!
(& That's my story & I'm sticking to it!)
Ok, so I understand the 06 being made in 2005, I see that at the assembly plant everyday, But how do you figure 0113 is at the end being a #92x or #93x??
First, your 0113 is Day of Month & Hour Built.(Not you VIN which in your case is very similar)
Well it's quite simple really, if you read all of this thread, or just post # 457 ,
"Originally Posted by tom2112
The last 2005 I have in my list is #64169(s/b 1st 2006 SRT6) and right behind it is #61033(s/b Last 2005 SRT6)."
If 61033 is the end or very Close, then your 61011 (see below), is also very close, & not every # in between is a SRT6, more than likely.
BTW, you have you Own 3's mixed up:
The last 5 numbers are: 61011.
Date: 06/05
MDH 060113
I keep meaning to post my car's info here to add to the database.
Here goes:
Date of Manufacturer: 07/04
VIN: 038717
MDH: 071911
Cheers,
KrzyFast
Here goes:
VIN: 038717
MDH: 071911
Cheers,
KrzyFast
No, yours is one of the Very last 2005 SRT6s Built!
Originally Posted by RMADERMAN
SF, my s/n is 60387 w/ a mfg date of 05/05. His was probably mfg'd in April or May along with mine since the s/n's are so close.
Originally Posted by rodimus
I'll ad my serial number later..... where do you find it, is it the MDH number. I'm pretty clueless when it comes to automobiles-
Date: 06/05
MDH 060113
Date: 06/05
MDH 060113
Strange that your VIN in before mine 060113/60387 but your build date is later then mine 06/05..05/05. That does not make any since. Unless your VIN is wrong as you stated. Maybe your VIN is actually 61013 ?????????
Take another look at his post
060113 is the MDH not his VIN
VIN is 61011 according to post on previous page
Very likely to be one of the last if not the last 2005 SRT
My Post # 466 above (Which I put together Very Carefully) points out his Error in his own Numbers, he got them mixed up.
He got the last Six of the Vin, switched with the MDH (6 digits), in another post of his mixed in.
These two sets are Probably the Correct ones for his XF:
(These #'s of his make sense & fit the sequence)
The(VIN) last 5 numbers are: 61011.
Date: 06/05
MDH 060113
Originally Posted by MI1XFIRE
Randy
I've just purchased an essentially new 2006 Crossfire SRT6 with a vin #64177 and a little over 800 miles on it at auction. Doing a quick search on the net it appears there were very few 06's built, supposedly around 12-13...though unconfirmed. I haven't been able to detemine definitively how may 06s were made or what the true last vin number really is. I've read a few of these blogs and it still doesn't appear very clear. Does anyone know the answer???
Where are you located?
Here's my door tag, can I see yours?
