Sometimes Sluggish acceleration
  #221 (permalink)
Old 10-10-2008 | 07:53 AM
rodimus's Avatar
Default Re: Sometimes Sluggish acceleration
add my car to the IC Pump list...
Would you think this would be covered under the powertrain warranty? Of course my Stealership is trying to weasel out of this. I printed this entire thread and showed iit to them too. I wish violence was legal when dealing with anything car related.
I just called the general manager so hopefully that will do something.
  #222 (permalink)
Old 10-10-2008 | 08:06 AM
huudoo's Avatar
yes it should be.. mine was replaced under warranty
  #223 (permalink)
Old 10-10-2008 | 08:52 AM
rodimus's Avatar
Under the powertrain warranty or was it bumper to bumper?
Thanks for the help!!
  #224 (permalink)
Old 10-10-2008 | 08:56 AM
huudoo's Avatar
chit i think bumper to bumper... should be covered anyway
http://www.chrysler.com/crossbrand/w...t-Sprinter.pdf
2.2 Powertrain Limited Warranty
B. What’s Covered
The Powertrain Warranty covers the cost of all
parts and labor needed (less a $100 deductible per
repair visit at the end of the 3 Year/36,000 Mile
Basic Limited Warranty) to repair a defective
powertrain component on your vehicle listed in
section 2.2.I below supplied by DaimlerChrysler
Corporation that is defective in material, workmanship
or factory preparation
Gasoline Engine: cylinder block and all internal
parts; cylinder head assemblies; timing case, timing
chain, timing belt, gears and sprockets; vibration
damper; oil pump; water pump and housing; intake
and exhaust manifolds; flywheel with starter ring
gear; core plugs; valve covers; oil pan; turbocharger
housing and internal parts; turbocharger
wastegate actuator; supercharger; serpentine belt
tensioner; seals and gaskets for listed components
only.
  #225 (permalink)
Old 10-10-2008 | 09:23 AM
rodimus's Avatar
B. What’s Covered
only.
Thanks!! It looks like it should be covered. they of course only replace the temp sensors at first. They said that wasn't covered, I didn't arguer with that because i thought that made sense.
  #226 (permalink)
Old 10-10-2008 | 09:42 AM
huudoo's Avatar
i hear ya ,the tech at the dealer wanted to do the same thing went to a different dealer they ordered a pump for me ... once they replace the temp sensor take them for a ride .. get up some speed and they will see their was no change..
  #227 (permalink)
Old 10-20-2008 | 10:43 AM
rodimus's Avatar
I'm just going to order the Johnson Pump.
I've read posts saying that it is a easy install. Would you guys recommend installing this by someone with limited auto skills? If not, can any reputable mechanic do this or is a MB mechanic a better choice??
On a positive side note.... I was venting some frustration last night and told my GF I have to order a "Johnson pump", and she said "You don't need one of those things baby". haha
I said, unforutantely my car does though. She said I thought cars were usually woman??
needless to say was a very funny conversation that was needed, because Chrysler has been pssing me off quite a bit.
  #228 (permalink)
Old 10-20-2008 | 12:24 PM
cruzinquick's Avatar
You can do it yourself. Order the bosch ford lightning pump, as it will be easier to install. You actually don't even need to disconnect the hoses, because you are using the same top. Just remove the screws from the top and the body of the pump will remain in the bracket. Remove it and reverse the procedure, then get the plug to wire into factory wiring. You should use hose clamps to pinch the hoses, to help keep the water in the lines and not on your garage floor. here's one but plenty others on ebay. Remember to get the plug or just use spades to plug into the bottom of the pump.
http://cgi.ebay.com/ebaymotors/03-F-...mZ170272871905
  #229 (permalink)
Old 10-20-2008 | 12:41 PM
waldig's Avatar
Talking Re: Sometimes Sluggish acceleration
Your continued donations keep Wikipedia running!
Thought that it might be of interest to the younger crowd to learn where the Johnson term came from, Enjoy WOODY
Johnson bar (tool)
From Wikipedia, the free encyclopedia
Jump to: navigation, search
A Johnson Bar, aka "J"-bar, is a lever-dolly; (a wheeled prybar having an extended handle and a deep reverse-beveled nose-iron), which is used to jockey heavy apparatus into position.
Johnson Bar
This tool article is a stub. You can help Wikipedia by expanding it.
Retrieved from "http://en.wikipedia.org/wiki/Johnson_bar_(tool)"
Categories: Tools | Tool stubs
ViewsPersonal tools
if (window.isMSIE55) fixalpha(); NavigationSearch
InteractionToolbox
if (window.runOnloadHook) runOnloadHook();
  #230 (permalink)
Old 10-23-2008 | 04:34 PM
rodimus's Avatar
I'm finally getting my Johnson Pumped this weekend. I can't wait to have my baby back to full power.
  #231 (permalink)
Old 10-23-2008 | 04:57 PM
MikeR's Avatar
Getting your 'Johnson PUMPED'? That sounds good.
MikeR
  #232 (permalink)
Old 10-23-2008 | 06:15 PM
I took my johnson out of the box this evening and handed to my mechanic....now he can play with my johnson until it improves my flow....
  #233 (permalink)
Old 10-23-2008 | 07:32 PM
mrphotoman's Avatar
it is a super simple install, i would rather do it myself than to trust someone else with it.
  #234 (permalink)
Old 10-23-2008 | 07:41 PM
robby363's Avatar
LMAO... Did he get it flowing for you yet.
  #235 (permalink)
Old 10-23-2008 | 07:55 PM
Lotus F1's Avatar
This statement is wrong in so many way's
Please tell me your mechanic is a female. Lie if you have to.
  #236 (permalink)
Old 10-23-2008 | 08:10 PM
BrianBrave's Avatar
<--- Huge Horsepower
I always keep my Johnson handy in case I need to "Whip-It-Out"
  #237 (permalink)
Old 10-24-2008 | 06:06 AM
rodimus's Avatar
I heard it was a a pain in the ****. Isn't there wire splicing involved or something?
  #238 (permalink)
Old 10-24-2008 | 07:01 AM
MikeR's Avatar
'I heard it was a a pain in the ****. Isn't there wire splicing involved or something?'
Now that is just REALLY wrong!!
MikeR
  #239 (permalink)
Old 10-24-2008 | 08:19 AM
mrphotoman's Avatar
i used the lightning pump and wire harness, it took all of 10 seconds to splice in the harness.
  #240 (permalink)
Old 10-24-2008 | 08:20 AM
rodimus's Avatar
MikeR
Oh??
I'm clueless so TVT is installing this weekend and that is what I was told??
Quick Reply: Sometimes Sluggish acceleration
