158 Mph
Old 06-21-2006 | 10:59 AM
feets's Avatar
Default Re: 158 Mph
Originally Posted by Eracer76
That's right, there are times were horsepower doesn't mean squat when it comes to top speed.
Even if there were two of the same cars, one with 700 hp and one with 900 hp and both were able to hit redline in top gear, their both going to top out at the same speed due to the gearing/rpm limit of the engine.
That's when you change the gearing to take advantage of the power produced by the stronger engine. The lower power engine won't be able to hit the rpm afterwards. Thus, the higher power engine is the faster way to go.
But it is true that if I stick a blown alcohol motor in a go cart without changing the gearing, the little 5 hp Briggs & Stratton will have the same speed at the same RPM.
Old 06-21-2006 | 01:44 PM
Jerry_Hubbell's Avatar
Default Re: 158 Mph
Originally Posted by scot1981
power has nothing to do with top speed, it has to do with gearing and aero dynamics.
What kind of nonsense is this? Of course power has everything to do with top speed. As the car goes faster the aerodynamic load increases to where the horsepower limit is reached and balanced by the load. What speed that occurs has nothing to do with RPM, unless the RPM is limited before the peak power occurs.
Jerry
Old 06-21-2006 | 02:45 PM
scot1981's Avatar
Default Re: 158 Mph
you can have all the horse power in the world and it is shaped like a brick it will not beable to reach top speed like that of a smooth wedge shape one with 1/2 the power. also if you ever watch some cars that drag race that have 500-700 hp that only reach speeds of of like 130 or so, if they had that power in a more aero dynamic car with taller gearing it could go nearly twice as fast. i was mearly over stating that power namely is not as important and gearing and aero dymanics. just look at the c5 corvette and the c5 z06, z06 had more power with only a slightly higher top speed, 5-10 mph.
Old 06-21-2006 | 03:53 PM
former NXMX5's Avatar
Default Re: 158 Mph
^ you must mean shorter gearing...
Old 06-21-2006 | 04:33 PM
feets's Avatar
Default Re: 158 Mph
There are two kinds of top speed. Aerodynamic induced and RPM induced. If your car doesn't have the wheaties to push the air out of the way at a 6,000 rpm redline in top gear, you're simply not going to hit that rpm. Therefore, your speed is limited by aerodynamic drag. If you add power and are able to hit the target RPM, you're going to have a higher top speed that will become RPM limited. In this scenario you run out of gear, not motor.
The non-SRT cars would probably be aerodynamically limited if the artificial limiter wasn't there.
There's not much RPM left after the speed limiter kicks in so it'd probably be rpm limited.
Old 06-22-2006 | 12:13 AM
05blacksrt6's Avatar
Default Re: 158 Mph
Originally Posted by andrew
~ almost all speedometers read higher mph than actual... especially true at high speeds. 10 mph greater than actual mph at the speed is about right.
that is not true at all. this isn't the 60's when cars speedos and driven by gear off the trans. there has been countless times when i have passed those cop things that show your speed and it was dead on every time at 25 mph or 75 mph didn't make a difference said the same thing in the xfire. ill try and take a pic next time i do it to show your guys (just hope i don't crashing trying to lol).
Old 06-22-2006 | 08:21 AM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: 158 Mph
here is an interesting article for ya:
http://www.caranddriver.com/article....&page_number=1
Old 06-24-2006 | 10:53 AM
Coyote's Avatar
Default Re: 158 Mph
Originally Posted by former NXMX5
SRT6 hits 150 mph in 37.6 sec (hits 130 in 23.4), according to the article:
http://www.caranddriver.com/roadtest...ire-srt-6.html
XF hits 70 mph in 8.2 sec, (hits 130 in 32.2) according to the article:
http://www.caranddriver.com/roadtest...crossfire.html
extremely exaggerated seems about right to me...
Thanks for the info. I know it was exaggerated, but that ain't the point.
I see the 150 mph number you have above, but it just seems too long.
I haven't yet gone that fast, but I'm sure I was at 145 a lot quicker than
that. Tell you what... I'll break out my stop watch and see if I can't find a
nice empty back country road with a long enough straight away, without
any infrastructure around, or cops, and see what I can do. Not sure when
I'll get around to it, but will try tomorrow evening.
Coyote
Old 06-24-2006 | 11:14 AM
Monsterpost's Avatar
Default Re: 158 Mph
The above statement is true, however the car with 900 hp will get to redline quicker in top gear, everything else being the same.
Old 06-25-2006 | 02:04 PM
Eracer76's Avatar
Default Re: 158 Mph
True, but I think the original topic was top speed, not who gets there faster.
Old 06-25-2006 | 05:25 PM
feets's Avatar
Default Re: 158 Mph
Then you change the gears to use the extra 200 hp. The bigger power combo will go faster because the other setup doesn't have the power to use the taller gear.
crossfireusa
10-28-2015 12:03 AM
jimf
10-10-2015 10:22 AM
grip grip
Other Cars
09-26-2015 09:52 PM
tritongreen
09-18-2015 07:32 AM
Quick Reply: 158 Mph
