Automatic Top issues
Hello to all I have an issue with =
2005 SRT6 Roadster, Automatic Top won't go up correctly. I can get it back down and in the correct final position with the boot closed and no warning light. When I try to put the top up it stops about 1/2 to 3/4 of the way up and stops, then I get the warning light and alarm/beeping. If I pause and continue to try and close the top will go too far and actual hit the top of the cowl/windshield. the back window is not in the correct position and the automatic boot is in the up position. I post this originally in the Technical section yesterday but I thought I would post here too.
Thanks to all for any help.
Drive Fast
Steve
Drive Fast
Steve
Re: Automatic Top issues
Sound like an issue with the sequence, I'd bet the alarm you hear is the Top Control module sending an improper cylinder position, due to a bad sensor, of course.
Has any work been done on the top ? Any chance a sensor was damaged of compromised in any way?
If you can provide a short video of how it acts, we can probably derive which sensor is failing to report correctly.
No I have owed the car since last August, no work on the top. I haven't had any issues with the top at all. No alarms, I thought it was slow and noisy but to be honest I have no reference on how fast or loud it should be. I have had the top up and down 30-50 times I have driven almost every week I had decent weather and the top down when I could and not seem crazy!
I have the top up and secure and will post a video on when and if it will open. I took the pressure of closed the top manually and used the 6mm allen to secure the Latch. Thanks for responding so quickly, I know that this the best fourm for any car group.
Steve
Steve
Fluid is way below the min line so I ordered Mercedes hydraulic fluid recommended by Top Hydraulics, they have great videos on our ragtop operation and troubleshooting on Utube. I will get back later when I get fluid back to full and see what happens next.
Thanks to all.
Steve
Thanks to all.
Steve
Thanks to all.
Steve
Thanks to all.
Steve
I asked that on your other post. Glad your getting fluid in there. Keep us posted?
So I was very lucky. The fuild Reservoir is now full I worked the top manually to get it to relearn or correct order of the sensors and working better than ever. I don't see a leak as of yet. It must have been really low when when I bought the car last Aug or when the new top was installed a year before I bought it? Is there a way to leave the tonal cover up to see if it leaks down? Pizzaguy thinks there has to be a leak and I fully believe in his advice! Any way again thanks to all who helped and I appreciate everyone and all the great tips and advice on the forum. Sun is out top is down and I'm on the road.
Troutkill
Drive Fast
Troutkill
Drive Fast
I use a collapsible "Trekking Pole" to prop the lid up, when the pressure releases, the pole will hold it up.
https://retrospec.com/products/solst...hoCu0YQAvD_BwE
Troutkill
03-27-2022 11:00 AM
