Center console
Re: Center console
search for the link to the documentation on this site and download the service manual, it should have all you need to complete this task and many others you may encounter.
If memory serves me correctly, use a trim stick to carefully pry up the trim ring around the shifter, and the console trim, it will expose 2 screws at the front. There are 2 more under the lining inside the rear console bin if you need to remove the entire console...
