Top beeps but won't go down
Just am FYI
I had an intermittent problem with a beeping sound and no movement when trying to put the top down. The windows would go down and then only the beep, no top movement. I was going to replace the switch on the top rail just above the passengers head. It can be seen, sticking up, with the top locked. I realized it could be a weak ground and tried tightening the two mounting screws. Lo and behold, they were not tight and after tightening them the top works great.
Bottom line, always check first for a loose connection causing a weak ground.
Fuya
15
05-15-2017 12:09 PM
12345
02-29-2016 04:33 PM
