Help changing passenger power seat switch.
Re: Help changing passenger power seat switch.
There is a Torx T20 screw at the front of the panel inside. Once removed pull down and forward. Much easier if you remove the seat first. The switch can be unclipped from the inside of the panel.
Thanks.
OK, so I was able to remove the switch panel , but I cannot see how to remove the wires from the main connector under the seat. Any ideas short of cutting and splicing the wires?[IMG]http://i1297.photobucket.com/albums/ag24/Randydaman1/2012-10-22125249.jpg[/
IMG]
IMG]
Kodebuster
11-05-2020 05:06 PM
axnguyen
07-21-2015 12:41 PM
