Battery crap on battery mounting plate?
I've pulled the battery and mounting plate twice on my SRT6 to remove that white powdery stuff that sometimes grows on the battery terminals. Except this was around the plate under the battery and was rotting off the paint and rusting. I thought it might be due to the higher heat put out by the SRT6. However, I just noticed this when I looked at my roadster battery. It's still oem.
Any idea what causes this? I did store the car for 5 winters, the last with a float charger. I do plan to remove the battery and plate in the next few weeks, scrape, repaint and remount. I also will add those little red/green pads under the terminals, hoping that will help.
on
Re: Battery crap on battery mounting plate?
Those little red and green pads did it for me. Have you seen any evidence of the overflow vent box (little white doohicky) leaking/full? that would be overcharging. Even if it didn't actually overflow, as the acid evaporates it can cause damage to paint and bare metal alike. I replaced my battery with a WalMart special and it came with an elbow and a tube for the overflow. I attached about 3' of teflon tubing and routed it down and under the car.
As your battery is the OEM battery you should have the plug installed. My new battery did not have a trap or a plug and I reinstalled the OEM parts.
These should be in place to prevent spillage and the damage that ensues when they are not.
If anyone tops up the battery with water they should remember not to get too liberal with the water or it will overflow, fill the trap if installed and leak all over the car.
on
x1xsinisterx1x
08-24-2015 07:31 PM
