Tire Pressure Sensor
Old 01-05-2009 | 08:22 PM
LVXF's Avatar
Default Re: Tire Pressure Sensor
I can attest to cold temperatures tripping the TPM indicator light. Here in Las Vegas, the temperatures can reach 120 degrees in the summer (probably hotter at pavement level). In the winter, the temps can dip into the teens. That's when I get a TPM warning. I pump up the tires to the proper level, and it usually takes the computer about 90 minutes, give or take, to reset. I've only had to do it twice ever, so I'm not complaining.
Old 01-06-2009 | 08:27 AM
todk64's Avatar
Temperature shouldn't matter if you have less than 4 wheels losing air. Is it all 4 going down equally? Is just one wheel? My guess from the 1st post was that you have a slow leak in one of your tires. When it gets cold, you lose pressure, but they should all be losing airfairly equally. How many miles are on the tires? A Pot hole may have bent a rim, or it could also be fixed by removing the tire, and cleaning the inside of the rim and re-mounting the tire. If the Tire is out of round, (Broken Belt) or the rim has a slight bend in it, it can be found when its re-balanced.
just my 2 cents
Old 01-06-2009 | 08:47 AM
Bladecutter's Avatar
just my 2 cents
New sensor fixed the issue as OP reported in post #20.
No more dash light, and no more slow leak.
BC.
Old 01-06-2009 | 11:52 AM
rodimus's Avatar
BC.
I think he was just adding to the discussion.... giving some Dealer Insight..
Old 01-06-2009 | 05:45 PM
LVXF's Avatar
When my TPM tripped, I checked the pressures on all four tires and they were equally low so I can only assume that it was because of the temperature. Would be interested to know what should really trip the indicator.
Old 01-06-2009 | 07:52 PM
How about low air pressure.
Old 01-07-2009 | 11:14 AM
todk64's Avatar
Thats funny.
Old 01-13-2009 | 01:30 PM
LVXF's Avatar
Red face Re: Tire Pressure Sensor
I had to laugh, too!
Old 01-13-2009 | 01:41 PM
faiz23's Avatar
that was quite funny but i read that high pressure can trip the sensor too lol is that true
Old 01-15-2009 | 06:58 PM
Harmie's Avatar
I experienced the same issue and my dealer found that it was the sensor that had developed a hairline crack. Originally it was thought to be the valve stem (replaced) but the second visit revealed the issue with the sensor which was then replaced. They also recommended nitrogen and I switched.
Old 01-15-2009 | 08:07 PM
maxcichon's Avatar
Interesting. They are one-piece sealed units. The sensor IS the valve stem.
Old 01-15-2009 | 08:15 PM
Originally he lied or unscrewed and replaced the valve insert and not the stem.
Old 01-16-2009 | 09:09 PM
Harmie's Avatar
Should have been more specific - the gasket was thought to be the issue and this was replaced; however it was the stem itself rather than the gasket.
Kodebuster
11-05-2020 04:06 PM
Danyuhl
11-02-2019 05:18 PM
velociabstract
16
10-12-2015 10:56 PM
Bifftws
Racing
07-28-2015 05:31 PM
axnguyen
07-21-2015 11:41 AM
Quick Reply: Tire Pressure Sensor
