Cleaning those wide wheels all the way through
Re: Cleaning those wide wheels all the way through
yep me too , took both front tires Pilots stright tread off today Rotated tham..
also cleaned the inside rims, i sprayed greesed lightning on the inside
used a tar brush , i was amaized how easy they cleaned up after
12,000 miles
i don't have the black dot things you all speak of, of course i clean my rims
once a week whether it need it or not.
i have a soft brissle, tire brush i got at walmart for like 2.87 works great
12,000 miles
Originally Posted by oledoc2u
Gee...I learn sooo much from these here forums...I use a spray I purchased a my Harley Dealership, spray on, hose off...works on the Harley and the wheels, FP do you allow your daughter to date older men?....as for tire rotation, that is called I will buy new ones when the old ones wear out, which will be when I tell my spouse I need new tires and rims for the car....again.......Doc
Originally Posted by popeye
Not having much success on a method to clean the wheels. I'd like to develop a tool and chemistry that would let me get rid of the crud that the road and brakes lay down on the inside of those wide wheels. Can't get my hand between the spokes.
Anyone have a suggestion?
Please see my post on detailing...I found some stuff for the black spots that won't come off right here in Ocala. Small company that sells only detailing products. Their Dreaded Red or Wheel Cleaner will make short work of that baked on stuff...
As for magical miracle cleaners, my dealer turned me onto one. I brought my car in over the winter with what looked to be rust on my rims, that no matter how hard I worked at through the winter and afterwards it would not go away, and I tried everything. Anyways I wanted to see if I could get the rims replaced, but the dealer called me back after having my car for a few hours and said they couldn't get the rims replaced because they cleaned them entirely. I doubted it, but when I got there the rims were spotless, they looked brand new. Anyways the stuff that they said they used but could not sell to me was called purple dragon, I have never taken the time to order it because I have been able to keep them clean since they cleaned them but here a website I found that sells the stuff.
http://www.k-chemicals.com/pages/autoallpurpose.html
You have to scroll down the page a little bit but its there.
When I initially bought the car I took the wheels off and cleaned them spotless on the inside and out.
Then I coated them with a wax.
Now for the past year once a month I simply jack up one wheel at a time and lay under the car and turn the wheel as I clean it on the inside just using a wet towel. Done. Looks fine.
Now if only i can find some matching touch up paint......Grrrr!
I use a brush designed for cleaning motorcycle spoke wheels. (I use it on the bikes too, LOL) Got it at J&P Cycles, their P/N 910-221 works great.
Here's the link:
http://www.jpcycles.com/ProductDetai...910-221&cs=All
Here's the link:
Here's the link:
Here's the link:
I'm looking at that brush thinking its very similar to a brush used for cleaning glass baby bottles and that it can be purchased more conveniently and for allot less money.
Idrenak
09-19-2015 08:17 PM
tritongreen
09-18-2015 07:32 AM
