TVT DESIGN CAI Install
Old 02-05-2008 | 06:48 AM
madduc's Avatar
Default TVT DESIGN CAI Install
I just received my CAI from TVT. Instructions are GREAT but.......
has anyone had experience feeding the flexible plastic tube into the hole behind the driver's side headlight? Tips and hints will be appreciated.
I'm new to the Forum and have a 2007 N/A base roadster.
TIA
Old 02-05-2008 | 07:02 AM
batchain's Avatar
Default Re: TVT DESIGN CAI Install
TIA
Yes. I had a heck of a time doing the same thing! It's very difficult to feed that flex tube under the headlight. I found it was much easier feeding it from the front side, underneath the car, back into the engine compartment. This is backwards from the TVT instructions. You have to remove that bottom engine cover to get there though which is also in the TVT installation instructions.
Old 02-05-2008 | 12:15 PM
madduc's Avatar
Thanks, BATCHAIN. It worked!! Got the CAI in.
Old 02-05-2008 | 12:37 PM
batchain's Avatar
Great. Yeah it works much easier in that direction.
Also, FYI, I got a Mercedes ML320 engine cover that with a little modification will fit the TVT CAI setup. TVT now sells these as a package deal. You can see a pic in my User Gallery.
Old 02-05-2008 | 01:48 PM
Can you get a pic of where the intake is located behind the grill ??
The other pics in your gallery look great. Thanks
Old 02-05-2008 | 01:51 PM
batchain's Avatar
I'll try tonight. It's in a very tight spot to take a picture of clearly as it goes through a opening immediately under the headlight assembly.
Old 02-05-2008 | 02:00 PM
Do you feel that this location has good for air flow for the intake ??
Is it possible to use the existing intake port with this mod ??
Old 02-05-2008 | 06:03 PM
batchain's Avatar
I think the location is good. It's outside the engine compartment so it'll be sucking cold air. The existing holes for the old intake tubes are too small to fit the 3" flex pipe through. You can just make out the existing hole directly above the start of the silver intake pipe.This location under the headlight is just barely big enough. This pic shows the location of the inlet tube under the light. The K&N cone filter on the other side is attached to this flex tube and is protected by the bumper and the bottom engine cover.
Old 02-05-2008 | 06:16 PM
TVT_DESIGN
Guest
Posts: n/a
Hey guys,
Glad to hear our products are receiving positive response. The stock inlet holes will not work due to their size and limitation for filter. I feel the way we have designed our intake is as good as it is going to get for the N/A airflow path. It's a 3" uninterrupted flow right to the MAF.
Anthony
TVT Design
Old 02-05-2008 | 07:30 PM
Thanks for the pics and detailed info.
55chevy
07-22-2024 02:31 PM
Jonacross
20
07-17-2017 11:19 PM
zackman62
11-06-2015 12:37 PM
Ralph289
09-21-2015 09:34 PM
bbsrt6
09-19-2015 11:21 AM
Quick Reply: TVT DESIGN CAI Install
