Installed Lighted wind restrictor...
Old 01-12-2008 | 10:24 PM
jaded1958cars's Avatar
Default Installed Lighted wind restrictor...
I just installed my (blue) lighted wind restrictor...
I just figured out how to upload photos..Here it is
I had the option to hook it up to the brake light or running lights. I chose the running lights.
I'm now thinking it may be too bright to have it illuminated 24/7 and when lighted, appears to restrict the ability to see out the rear view. (It hasnt been out of the garage yet)
Can others share their expereince and hook up.
Thanks so much.
Old 01-13-2008 | 02:42 AM
crossfirefun's Avatar
Default Re: Installed Lighted wind restrictor....
I have mine hooked to the tailights and didn't like the reflection/light while driving. I left it hooked to the
tailights but now also have a switch mounted between so I can shut it off on long trips.
Old 01-13-2008 | 02:56 AM
Thats a good idea....I wasnt looking forward to the idea of unhooking it and re-wiring...Leaning over the trunk lip isnt much fun.
So do you still drive with it on occasionally?
Old 01-13-2008 | 03:22 AM
It is sleeping for the winter so I dont know how much I will use it next year. I only had it installed for the last month I drove it.
I have the switch mounted in the bulkhead behind my seat.
Old 01-13-2008 | 05:27 AM
blackberry's Avatar
I did the same, hooked it up to my taillights, bought the switch offered and drilled one hole up in the corner behind the drivers seat. It's a little tight working in there but pulled a little wire and it hooked up real easy. It is bright with the top up so I run it both ways depending on my mood.
Old 01-13-2008 | 07:53 AM
Scott_lmtd's Avatar
Same here, installed to the lights as you did, added a mico swicth behind the passenger seat in between the carpet and plastic trim to turn on and off. You can pull the plastic strip off with the LED's and de-solder a couple of the LEDS as well. If you look in my gallery I have a picture of the LED switch and where is mounted.
Old 01-13-2008 | 02:39 PM
Cool Re: Installed Lighted wind restrictor....
........ Thanks for the advice
In reading this post Keep in mind that that I am a new owner and that my car is sitting in my garage unregistered. I havent been able to drive it yet, not to mention the snow.
I discovered t the wind restrictor light is really bright while the parking lights are on. However, they dim considerably with the running lights on.
I have a dumb question....With the key out of the ignition does your brake light go on when you depress the brake peddle? Currently it appears i have to have the key on. Is this normal or do I have a possible wiring problem?
Thanks for all your help
Old 01-13-2008 | 03:46 PM
I installed mine and also wired it to the rear driver's rear light, and added a switch to turn them off when my top is up. They won't turn on when pressing the break, unless you wired it that way. You can also add a dimmer to make to dim it to your taste.
Old 01-13-2008 | 04:24 PM
golfergal's Avatar
I have my windscreen hooked to my lights. When they are on, it's on. Yes, it's bright with the top up and in the pitch dark, but it's fine once I start driving and I can see just fine out of my rear window...backing up is a bit tricky..hence, I'm having to replace my side mirror..that's another thread...
I have the switch to have a dimmer switch installed and/or have it hooked to my brake light so it will illuminate more brightly when the brakes are on. I love this illuminated windscreen...when the top is down and the lights are on, it's a true show stopper...I only have to wait 5 more months or so for that to happen...unless we get a heat wave in Seattle!
Old 01-13-2008 | 04:36 PM
I do believe with the key off the brake lights dont work and the horn doesn't blow. Not sure though as like you mine is put away.
Old 01-13-2008 | 05:23 PM
woodlands1's Avatar
I have my Windrestrictor wired to a hot 12V line and have a switch mounted behind the driver's seat to turn the leds on/off. I have control over when the leds are illuminated and prefer it that way.
Top up or top down, it looks great. Nobody will mistake the fact that the car is a Crossfire (assuming that you have the Crossfire script etched into the Widrestrictor).
Old 01-13-2008 | 06:26 PM
So much for dimming when the headlights are on.........The top wouldnt retract and I muddled around thinking the partition was out of allignment....It turned out the battery was depleted..That would explain the led's dimming when the lights went on. I'm such a putz sometimes.
Now if only i could learn how to upload pictures not that I'd be posting anything new.
Old 01-13-2008 | 06:30 PM
woodlands1's Avatar
What caused your battery to loose charge?
Old 01-13-2008 | 06:40 PM
........ I have a dumb question....With the key out of the ignition does your brake light go on when you depress the brake peddle? Currently it appears i have to have the key on. Is this normal or do I have a possible wiring problem?
I just went out to the garage and checked this out. I learned another thing I was unaware of. The brake lights and horn do not work when the ignition is OFF.
Old 01-13-2008 | 06:45 PM
Seeing double vision again
Old 01-13-2008 | 06:48 PM
Now I dont feel so bad Gary..Even a Crossfire guru like yourselfcan learn new tricks .LOL
I am running out of Crossfire jobs....I have a headache thinking I now need to learn to use the Navigation.
Cheers!
Old 01-13-2008 | 06:58 PM
[golfergal]I have my windscreen hooked to my lights. When they are on, it's on. Yes, it's bright with the top up and in the pitch dark, but it's fine once I start driving and I can see just fine out of my rear window...backing up is a bit tricky..hence, I'm having to replace my side mirror..that's another thread...
With the light on I wonder if people ever think...."Hey look at the Smurf driving the cool car"
Old 01-13-2008 | 07:46 PM
DP XFIRE's Avatar
Don't mean to hijack this thread, but have a question. Has anyone ever been given a traffic ticket running the lights on the wind restricor? I have a blue roadster and ordered the blue lights, just too cool until I remembered Texas law: bed, amber, and white lights only visible from the back of the vehicle. I asked the local chief of police (my neighbor) about the blue lights. He told me that it would only be a matter of time before some cop, somewhere would hassle me and write a ticket for it.
Has anyone had a problem with this, or were they smart enough to order different colored lights, lol.
Old 01-13-2008 | 07:58 PM
golfergal's Avatar
No...I have the same color and was told it was not a problem...I asked before I bought mine, too and we have the same law...
..I'm just saying what I was told..have never had a problem at all...
Old 01-13-2008 | 09:33 PM
Yeah but you're blonde and good looking like my wife who never gets a ticket for anything! Just smiles sweetly..Yes officer?
Quick Reply: Installed Lighted wind restrictor...
