Spoiler painted - now won't retract all the way
Old 12-02-2021 | 02:30 AM
UrbanE's Avatar
Default Re: Spoiler painted - now won't retract all the way
This appears to be a really activity trap
you might be better served in buying a new wing and just replacing it.
The cost associated with more time to correct the issue will more than cover a replacement.
or
You can work on it another 2-3 months and come to the same conclusion
Look on eBay
(BTW if you’re planning on keeping the car for awhile, it’s a good idea to start collecting spare parts.)
I don’t think anyone is making that wing for any other cars. Not a bad idea to have a spare.
Old 12-02-2021 | 10:56 AM
or
Look on eBay
I think you an take the motor out and then you could see if the mechanism works. Forcing it may do more harm than good.
Old 12-03-2021 | 01:49 PM
nickwe21's Avatar
or
Look on eBay
Thanks for your reply. What would I be looking for? Does the used wings on eBay come with the assembly and joint? I see some are selling the motor separately but I feel like my motor works it seems to be an issue with the assembly. Thanks for letting me know.
Also how difficult is it to replace the wing?
Old 12-03-2021 | 02:54 PM
UrbanE's Avatar
Wing is super easy to remove and replace
Start by disconnecting the negative battery terminal
Don't mess around with motor and mech just buy a complete set (the Price for replacement part is equal to or less than 1 hour door rate at most service centers)
I've attached a link to one here
04-08 Chrysler Crossfire Coupe Rear Trunk Spoiler Wing w/ Motor White Tested OEM | eBay
Installation is super easy ( If you can work a basic set of tools you can do this. But its a good idea to have a torque wrench that capable of 6 Ft/Lbs or 71 Inch/Lbs. You don't NEED the Torque wrench BUT if the job's worth doing, its worth doing right)
Download a copy of the manual (located on this site)
See section 23
start at Page 116
(I've attached a low res copy of the Manual pages required)
You can remove your spoiler from the existing mech and motor
replace that item and reattach your spoiler to the new motor/mech assembly
Replace both mech and assembly and keep your existing for parts
This should take you 2 hours or less. Most likely less.
Just cover the painted areas where your working, You don't want to drop anything onto the paintwork.
You want a smooth transfer with minimal F words, so read up on the process in the manual then execute. It might also be a good idea to get a cheap set of body trim tools they make removal of the lower trim Panel for Hatch and roadster.
Please let us know how it works out for you.
Knowledge = confidence
File Type: pdf
Old 12-05-2021 | 01:29 PM
UrbanE's Avatar
one more thing has just occurred to me and you probably know this
But
if you’re going to purchase a replacement wing be sure to get the wing and mech specific to your particular model
they are different for coupe and roadster.
I know that this is stating the obvious but the obvious can get over looked.
Happy Sunday
it’s snowing here today, crap I really hate snow
Bsaddor
05-20-2018 05:55 PM
radmanly
02-12-2010 06:38 PM
jackei
11-19-2007 06:09 PM
grphtmtlc11
06-19-2007 08:22 AM
X_firedude
09-01-2006 12:45 AM
