Rear Wing/Spoiler Installation
Old 04-23-2021 | 05:37 PM
Mikey208's Avatar
Default Rear Wing/Spoiler Installation
Hi all. I didn't see anything on this particular little detail so I thought I would ask.
I have removed the entire wing assembly from the car. I'm having the wing itself repainted and I want to do some other things. On the bottom of the plate that mounts to the car there is a sticky strip running around the edge of the inside. Do I need to do anything before I reinstall it or should it be fine as is? I don't want any leaks.
Old 04-23-2021 | 06:58 PM
Default Re: Rear Wing/Spoiler Installation
Did it look like it was leaking before you took it off?
This seal has a tendency to get pushed from between the faces it is fitted between. The foam seal separates from the sticky backing it was originally attached to and this causes leaks.
Leaks into the trunk can ruin the security pump in the trunk. The gap between the faces that trap the seal are not equal so a seal has to be thicker than the largest gap.
I used a seal that I made from a neoprene foam draft seal, you need the type that does not allow air through the bubbles in the foam.
I used 1/8” thick x 3/8” wide closed cell foam draft strip that I slit down the middle to 3/16” wide. Follow the out line of the sticky tape outline not where the foam ended up. I think if I did it again I would use a 1/8” thick x 1/4” wide seal.
Leave a small gap (1/4” wide) at the bottom to allow any leakage to escape.
Old 04-23-2021 | 07:06 PM
Mikey208's Avatar
No. I didn't see any signs of that.
Old 04-23-2021 | 09:50 PM
Mikey208's Avatar
Sorry, I didn't see the entire post. My stupid phone does that sometimes. Thanks for the help. I will make sure I do this prior to reinstalling. I don't need any leaks.
m3pig
09-28-2010 11:50 AM
bmorgan
10-20-2009 12:50 PM
almecum
11-29-2007 04:44 PM
pelked1
03-11-2006 02:03 AM
Cruiser
01-23-2006 12:06 AM
Quick Reply: Rear Wing/Spoiler Installation
