Keyless Entry Alert Passenger Side Lights Only Flash
Old 08-21-2016 | 12:19 PM
liljay's Avatar
Default Keyless Entry Alert Passenger Side Lights Only Flash
Has anyone seen this? When I lock or unlock the car with the key fob, only the passenger side lights flash. I have change all bulbs. Do know what's up.
Old 08-21-2016 | 01:18 PM
Default Re: Keyless Entry Alert Passenger Side Lights Only Flash
Only help I can offer, is make sure your ICM (light switch) is straight up/down AND check for water in the lower right rear 'trunk' where the central locking pump/module is located.
Old 08-22-2016 | 06:52 AM
liljay's Avatar
Thanks for the reply. No water in the trunk. I think it may the multifunction switch (turn signal), due to the fact I do not have high beam flash any longer. I will replace the unit and update. Thanks a lot for all you that you do!!!
MiamiTVR
16
01-20-2016 06:57 PM
tropixcale
01-03-2016 12:05 PM
crossfireusa
12-23-2015 11:38 AM
vickiepayne
12-17-2015 10:16 AM
Sunny9850
15
05-13-2004 02:22 PM
