Any one know how to decode the VIN??
Old 03-08-2005 | 12:09 AM
ViffeR's Avatar
Default Any one know how to decode the VIN??
I saw it on the Daimler Chrysler site before but I can't find the decoder now... I am tryingt o find out my build date...
My 1st gear keeps popping out but the dealer say it's not covered within the existing TSB. my build number is 5454...
It litterally scares the crap out of me every time it happens!
Old 03-08-2005 | 12:26 AM
leebea's Avatar
Default Re: Any one know how to decode the VIN??
The VIN doesn't contain a build date but I believe I have seen higher build numbers than that with the problem. Regardless, the problem is there and the vehicle is under waranty. The dealer has to fix it!
Here is the VIN code FYI anyway, and now it will be listed for anybody else's future reference:
Keep us posted on the results. Good luck.
CROSSFIRE VIN CODE BREAKDOWN
POSITION INTERPRETATION CODE = DESCRIPTION
1 Country of Origin........1 = Manufactured By DaimlerChrysler Corporation
2 Make..........................C = Chrysler
3 Vehicle Type..............3 = Passenger Car
4 Other.........................K = Restraint System Front Air Bags Next Generation
.........................................(CGW) With Standard Side Air Bag Supplement (CGS)
5 Car Line.....................N = Crossfire (LHD)
.....................................P = Crossfire (RHD)
6 Series........................6 = “S” Series
6 - Export Transmission.C = 6 Speed Manual (DED)
.....................................E = 5 Speed Automatic (DGU)
7 Body Style.................9 = Specialty Coupe
8 Engines......................L = 3.2L V6 SOHC 18 Valve
9 Check Digit See explanation in this section
10 Model Year...............4 = Model Year
11 Plant.........................X = Osnabrueck Germany
12 through 17 Sequence Number 6 Digit Sequential Number Assigned By Assembly Plant
Old 03-08-2005 | 12:38 AM
ViffeR's Avatar
That's exactly what I am looking for... Thanks for the quick reply!
I am going to call th dealer again tomorrow and threaten to take my business else where if they don't fix it... I'm telling you... It scares the crap out of me every time! The crappy thing is, I can't replicate the issue... It just happens, so when I take it to the dealer they tell me "no fault found"! Argh!
Old 03-08-2005 | 10:21 AM
C_Plunkett's Avatar
If you are looking for the build date, it's on the decal on the drivers door jamb. There is a date of manufacture which gives the month and year. Then there is the MDH which gives the month, day, and hour of manufacture.
Old 03-08-2005 | 10:02 PM
ytopless's Avatar
leebea... your VIN break down is nice, but doesn't seem to be quite right. I have a 2005 roadster with a 6speed, my VIN# is 1C3AN65L35X024968. If you plug in my VIN into your description a few digits do not match e.g. 4th, 6th, and 7th digit. I could understand the 7th digit, since mine is a roadster, but what about the other digits. If you have any additional information that would be great.
Thanks,
Jim
waldig
09-17-2015 10:35 AM
Geechee1962
09-16-2015 05:33 AM
da pink
08-12-2015 05:20 PM
FiftyThree033
07-26-2015 09:24 PM
oledoc2u
07-21-2015 07:08 PM
Quick Reply: Any one know how to decode the VIN??
