Key fob replacement case...
Old 06-21-2016 | 09:18 PM
chrono2nd.sr's Avatar
Question Key fob replacement case...
I took apart my key fob to put the guts in a new case, just replaced the siren. I can see corrosion on the board. Can this be cleaned up and fresh batteries replaced? I'm not gonna be able to get a new one soon.
Old 06-21-2016 | 09:19 PM
Question Re: Key fob replacement case...
And if it can be cleaned, how do I clean it?
Old 06-22-2016 | 11:25 AM
Mrmiata's Avatar
Default Re: Key fob replacement case...
WD40 and tooth brush..
(your wife will never realize it).. ..
That would be about as aggressive as I would go.. and should help prevent any more corrosion .
Looks like it got ran through the laundry at one point..
Old 06-23-2016 | 09:44 AM
I cleaned it with 99% rubbing alcohol and a q-tip. It didn't remove all the corrosion and I quit rubbing it with the q-tip when I seen some green of the board flake off. It is now working fine, 3 chirps lock, 1 chirp unlock. Should I take it apart and use wd40 on it?
Old 06-23-2016 | 10:17 AM
Mrmiata's Avatar
If it ain't broke... don't fix it..?
If it's easy enough to open (non of mine have been).. might crack it open in a month and see if corrosion is coming back or not..
rmgjr
06-25-2019 05:09 PM
CrossfireZona
06-13-2016 11:59 AM
Buggin
06-08-2016 04:24 PM
Danvelo1
06-03-2016 06:03 AM
texas t
05-31-2016 06:05 PM
