Radio Freezing???
Re: Radio Freezing???
I have had three of these Crossfire's with a radio freeze up and all three times the head light switch was left in the far left position and this leaves the running lights on the left side of the car on all night long and the Battery was run down just enough that on start up it spiked the system. Disconnect you battery and and recharge you disconnect to allow the capisotrs to discharge in the radio. Then you have a fully charged battery. Thank Terry OKC Crossfire?Viper Tech
Hmmmm, I know what you mean with the lights being left on...but I can assure you that is not the problem I had with my car! And to keep everyone updated, the 2nd dealer I had my car into yesterday said they couldn't find anything wrong that would make my lights "flicker." Soooo I guess I have to suffer with a $41k car that has an unknown diagnosis. God I miss my BMW!
Have Your dealer go to star-on and check k19182023 for radio inop and
K19182023
Vehicle Issue After Vehicle Is Started, There Is A 30 Second Delay Before Radio Produces Audio.
Year 2004
Model ZH - Crossfire
Engine 3.2L V6 SOHC 18V
Category Repair Procedure, Customer Concern (No DTCs), Diagnosis Test Procedure
System or Component Radio
Symptom Will Not Turn On, Responds slow, Inoperative
Case Verification Radio has ignition feed on start up on pin 7. Also has battery voltage on pin 4 and ground on pin 8.
If these are good then replace radio
Recommendation Replace radio.
K19182023
Year 2004
Selbyl
09-26-2015 04:15 AM
