I've only had it four days and I started disassembling it!
Re: I've only had it four days and I started disassembling it!
I'll add some links, better yet go to the link below and look under the Interior and Doors sections.
Actually, no. For some of it, I used the link to the SLK video that I am sure I found in the stickies. And of course, Reckah's How-TO on the sticky ignition fix that contains a lot of info on removing driver's side panels.
I would say everything I needed came from this forum!
Thank you!
Click on Disassembly, then Dashboard & Center Console. The only thing I found to be pain was the connectors on the back of the button "bar" below the A/C controls. Just watch the little video and follow the instructions and you will get it. If something seems as though it will not come out, make sure you have removed all of the screws before you use too much force and break the plastic. There are a couple of screws here and there that are a little hard to find - unless you read the instructions from the web site.
FOR THE RECORD - I DID NOT REMOVE THE GAUGE CLUSTER AS THEY DO ON THE SLK SITE - DIDN'T NEED TO.
Thanks to everyone for their support and compliments!!
Some people say the car is a keeper then suddenly the car is gone and so are they.
And others will have them forever and just lurk around
(Nothing like resurrecting old threads. ) And email alerts to keep you coming back.
Not everything is about you, there are other people on this forum and they have been around here more than nine months, you where just a passing shadow.
If you read the comment you will see that I say 'some people', not you. It is amazing how something is read in two separate sentences and then taken as a whole.
Passing Shadow, signing off.
She'll be done one of these days, then I will happily share some photos. Right now I am concentrating on designing the home Molly and I are going to build, plenty of room for cars, hell, I think I could even fit Crispy's collection in there when its done
