Camshaft sensor, cats, oh my...
Last week, got check engine light and code P0341.
Ordered camshaft position sensor, replaced today.
The only symptoms I was seeing was -- after warm, the car would on occasion, crank and crank but never fire up. The next key turn, it'd fire up with no problem.
The light went off/on for the week, but I replaced the part today and it was gone. Drove for about an hour, no issues..
then.. CHECK ENGINE LIGHT.. again.
This time, codes: P0432 and P0422. Both referring to cat performance, bank 1 and 2.
Does anyone have any idea why this has happened? Odd timing.
73,000 miles, '05 base coupe. Stock.
Re: Camshaft sensor, cats, oh my...
But it could be the air pump playing up, stuck or burnt relay in the RCM.
Must be a single source problem and not the cats.
I have never pulled a code for the cats before installing the replacement Camshaft sensor. I'm going to re-install the old sensor today, clear the codes, and see what comes back up. If the only code I pull after that is the original 0341, I can blame the other codes on a faulty replacement unit (cheap ebay part...). Update to follow!
Installed the original sensor, pulled negative terminal. Drove until check engine light came back on, pulled code -- only code present was 0341 again for camshaft. I guess my replacement part was defective? Ugh. Can anyone recommend a place to buy the camshaft sensor?
However, PelicanParts.com has a few options and Bosch is the OEM supplier.
http://www.pelicanparts.com/catalog/...pg3.htm#item11
Go Bosch or walk home.
Some of these cheaper sensors are crap and have failed to work out of the box.
Camshaft Position Sensor.
Bosch #0 232 103 037 (same as the OEM part)
2000 Mercedes ML320 Cam Position Sensor 0 232 103 037
rampntlion
21
02-11-2019 08:18 AM
bobbie
09-12-2015 12:49 PM
