Camshaft sensor, Crankshaft sensor and MAF later... still problems
  #41 (permalink)
Old 12-15-2012, 02:12 PM
maxime75us's Avatar
Default Re: Camshaft sensor, Crankshaft sensor and MAF later... still problems
ahah
Will it be a stupid move to change the Fuel Pump and the fuel filter.
I already have the fuel pump.
180. Would you be able to give me instructions to change the fuel pump? Please THX
  #42 (permalink)
Old 12-15-2012, 03:23 PM
maxime75us's Avatar
Hi,
I am going to replace the fuel pump and fuel filter (again).
Spending money ouch but ready to get ride of this problems...
The fuel filter was changed a few months ago by a mechanic but could you give me instructions in case the mechanic crossed the lines etc...
I want to make sure all hoses are correctly connected.
Please help.
Also To change the fuel pump, please could you give me instructions.
Thanks a lot,
MAX
  #43 (permalink)
Old 12-15-2012, 03:42 PM
Originally Posted by maxime75us
Hi,
Please help.
Thanks a lot,
MAX
Here's a pic of the filter and pump, no big deal to change though. Watch out for pressure in the line, maybe not in your case, but relieve the pressure safely and catch any spilled gas.
Look in the repair manual for instructions.
  #44 (permalink)
Old 12-17-2012, 04:17 AM
maxime75us's Avatar
Hi,
Did not see nor could find the your pic showing the fuel filter and pump?
Let me know, will change it tomorrow!
  #45 (permalink)
Old 12-19-2012, 01:26 AM
maxime75us's Avatar
Fuel Pump has been changed.
I will crank the engine tomorrow. Midnight now and do not want to be an annoying Dude.
Fingers crossed. If it does not work... !
  #46 (permalink)
Old 12-19-2012, 02:15 PM
maxime75us's Avatar
Hi,
So As I said last night I changed the fuel pump.
I cranked the engine this morning. NOT GOOD
Not very easy to start, maybe a bit easier but now you can hear and feel the engine is having hard time to run correctly. I dont think I can even drive it.
When I hit the gas, it dies... slowly but surely.
Please advise,
Thank You
Max
  #47 (permalink)
Old 12-19-2012, 02:20 PM
maxime75us's Avatar
Ok, second test.
When car is almost dying, the engine or .... regulates" and hit the gas itself to avoid a stall and over... dies almost and engine hit the rpm and try to regulate the rpm.
Please advise, it is killing me!
  #48 (permalink)
Old 12-19-2012, 02:43 PM
Mrmiata's Avatar
When's the last time you had battery disconnected? If it's been starving for fuel.. the computer has done all it can to try to dump more fuel into the system.. might be over doing it for the new pump? Disconnect for 10 minutes and try again?
  #49 (permalink)
Old 12-19-2012, 02:58 PM
Ok, second test.
Can you explain this please?
  #50 (permalink)
Old 12-19-2012, 02:59 PM
maxime75us's Avatar
I disconnected the battery last night while installing the pump.
Going to disconnect for 10 minutes and will try again
THX
Will post results, of course.
Max
  #51 (permalink)
Old 12-19-2012, 03:01 PM
maxime75us's Avatar
180. Was it a question for me??
Thx
  #52 (permalink)
Old 12-19-2012, 03:08 PM
Max, I have been following, and occasionally replying on this thread, but I am out of options.
If I were you, I'd search the membership list ( advanced search, enter 'Houston' in the location and sort by last posted to get current members.)
Try to contact them to get some different eyeballs on the problem.
Many there in Houston have extensive experience doing upgrades/mods etc, you can probably find someone that can help. Might cost you a 6 pack or two ......
  #53 (permalink)
Old 12-19-2012, 03:13 PM
Thx
Yes, I could not understand what you meant.
If the engine is knocking, I would normally say that the engine timing is out and it is advanced too much, or the ignition cables are on wrong.
I doubt the bearings are shot.
But I cannot see how the cables would reach when on wrong.
  #54 (permalink)
Old 12-19-2012, 03:25 PM
maxime75us's Avatar
Thank You,
After installing the fuel pump, I tried to start it. difficult like before. But this time ( after installing the pump) the engine almost dies and then go by itself on the 3K RPM to avoid the engine to die.
I can hear the pump running in the back... constant bzzzzzzzzzzz after 2 minutes
  #55 (permalink)
Old 12-19-2012, 03:28 PM
Thank You,
You can hear the fuel pump with the engine running, are you sure?
  #56 (permalink)
Old 12-19-2012, 03:32 PM
maxime75us's Avatar
Pretty sure, rear right wheel a constant bzzzzzzzzzzzzzzzz. I dont think there is many pumps or similar hardware to provide a nice a clear bzzzzzzzzz.
What do you think?
As always, I really appreciate the tremendous help!
  #57 (permalink)
Old 12-19-2012, 03:51 PM
Mrmiata's Avatar
Okay next train of thought.. If it was over pressuring the system (bad requlator).. what would the results be?
Maybe two problems going.. bad fuel pump (no pressure when tested) and bad pressure regulator? I ask this because an overpressure would cause the idle to rise wouldn't it? Too much fuel being delivered during the injector cycle?
  #58 (permalink)
Old 12-19-2012, 03:59 PM
maxime75us's Avatar
I just changed the pump last night
  #59 (permalink)
Old 12-19-2012, 04:27 PM
Mrmiata's Avatar
I understand that.. previously you said your friends gauge showed no pressure. Didn't this issue start shortly after changing out the fuel filter? Which has the built in regulator.. Have your friend check fuel pressure again and see if it read high now.. or none.. if none.. replace your friend.. and or his gauge..
  #60 (permalink)
Old 12-20-2012, 12:22 AM
maxime75us's Avatar
Mrmiata, you are funny and I agree with You!
The car is not drivable now. Friend with gauge is a few miles away. I can always buy one... at that point I am like :-(
I am going to change the fuel filter again. Was changed a few months ago.
I need to make sure where the two hoses from the back to the fuel pressure should go.
The front of the fuel pressure is easy. One go the Pump and one to the tank. Easy
The back of the fuel filter is confusing . One to the CAN" and ONE to the MOT"
Can you help me to recognize the hoses? Just to make sure, when the mechanic changed it 3 months ago. I did not crossed the hoses.
Please Help!
As Always, Thank You
Max
Quick Reply: Camshaft sensor, Crankshaft sensor and MAF later... still problems
