Rear Rotor Removal - PLEASE HELP!
Old 10-04-2012 | 10:32 AM
klamathpro's Avatar
Exclamation Rear Rotor Removal - PLEASE HELP!
So I now have 90k miles on the clock and I decided to replace my rear rotors. For the life of me I can't get them off. I removed the little star screw and the rotor is broke free and spins freely around the hub, but I can't get it past the e-brake. It jiggles to the point of trying to slide off but it gets caught on the e-brake shoes. I feel the e-brake shoes hitting a lip. I tried cranking down the hand-brake then released all the way. It just won't come off one either side. Am I missing a step that's different from other cars? Like an e-brake tension release of some sort?
Thanks.
Old 10-04-2012 | 11:02 AM
robby363's Avatar
Default Re: Rear Rotor Removal - PLEASE HELP!
You might have to turn back the adjusters on the shoes to get the rotors off.
Old 10-04-2012 | 11:21 AM
Mrmiata's Avatar
See if this helps you out..
https://www.crossfireforum.org/forum...tors-pads.html
Old 10-04-2012 | 11:48 AM
klamathpro's Avatar
That was it! Thanks a million, I would have never figured that out. I have never had to do that on any other car before. That little adjuster can barely be seen and took some finesse with a flathead screwdriver, but it eventually closed up and released the shoes. Now I can adjust my e-brake while I'm at it. Now I gotta jump in the GTS to drop off these rotors to get turned, they are still .35" thick.
Old 10-04-2012 | 12:14 PM
JHM2K's Avatar
Rough life
Old 10-04-2012 | 01:29 PM
I think I'd have probably used the RT/10
Old 10-04-2012 | 04:28 PM
90k and you want to machine the rotors? Why cheap out now?
Old 10-05-2012 | 11:20 PM
Warren Smith's Avatar
You know, I haven't checked but I would think that turning the rotors is almost as expensive as buying a new set and I don't mean from mercedes or chrysler. Not only that, if they are warped and you have them turned, they probably will warp again after they get hot. JMO.
PNA
11-12-2020 04:44 PM
Roty135
17
10-11-2018 10:11 AM
rocketrage
10-07-2015 05:00 PM
tom2112
07-28-2015 08:12 AM
Jerrysrt6
07-24-2015 09:15 PM
Quick Reply: Rear Rotor Removal - PLEASE HELP!
