Eurocharged ECU reflashed
Old 09-27-2012 | 04:53 PM
aquarilized's Avatar
Default Eurocharged ECU reflashed
Hey guys, a couple of days ago I did the throttle body upgrade to 74mm. Now I just left Eurocharged and got my ECU reflashed and I love the power my Crossfire has. I recommend this to all who want that extra oomph!
Old 09-27-2012 | 05:58 PM
zx3speed's Avatar
Default Re: Eurocharged ECU reflashed
Where are you going next with mods? I'm at about the same place after I order my tune next week and passing on the sprintbooster there's not a lot of mods left.
Old 09-27-2012 | 06:02 PM
redliner's Avatar
i second that, ive been debating the tb after reading mixed posts, but u can really notice it huh?
Old 09-27-2012 | 06:17 PM
I'm not sure what mods will be next. Im not very
interested in the Sprint Booster as well. Im always thinking of different things to do and hopefully something
will come up. I'm fortunate to be able to drive to Eurocharged whenever I need to, so I just got the ECU reflashed a couple of hours ago and am really enjoying my ride. Whatever I do next ill post it. Thanks!
Old 09-27-2012 | 07:27 PM
Dnivek's Avatar
Did you Dyno tune it? The last tune they did for me we just did over the internet with my laptop plugged into the car. I may go for the dyno tune next time. I just ordered my throttle body today. I also still have plugs and wires to upgrade when I get off my lazy a** and do it.
Old 09-28-2012 | 12:56 AM
No, i just stopped by and got the reflash then zoomed off on my way. If you get the Dyno done, can you post your results on here and note what mods you have. Thanks.
Old 09-28-2012 | 09:14 AM
gunner1374's Avatar
I want to do underdrive pulleys someday. Its something to think about next??
Old 09-28-2012 | 11:24 PM
Wow, that is something to think about. I will be thinking of things to do as well.
Old 09-29-2012 | 03:34 PM
zx3speed's Avatar
Is anyone still making an underdrive pulley for us?
Old 10-01-2012 | 09:46 AM
gunner1374's Avatar
Do a search on here for performance pullies. There is a link on page 2 to a company that makes them. Paul on here was claiming a 13 hp gain I believe from his pullies.
Try this:
http://api.viglink.com/api/click?for...13490994475461
Old 10-01-2012 | 12:26 PM
redliner's Avatar
couldnt you just turn your ac off and get about the same effect? my ultragauge shows a 5-7% decrease in engine load without ac at idle
Old 10-01-2012 | 01:44 PM
exshankerz's Avatar
Haha boy u guys are missing out not having the sprint booster! I thought the same until I ran out of mods to do... I would say 100% certain the sprint booster was the best mod it doesn't add HP but sure does make it feel like it adds a good 50! The dcai Eurotune and sp is all you need other mods you barely tell the difference! Unless you pump a lot of $$ into the engine , only mod ill be doing next is the begi turbo and ill be set! To finally keep up with the newer v8s out there
Old 10-02-2012 | 11:02 PM
falshami's Avatar
just ordered my eurocharged! i cant wait ! maybe it will finally spin the tires, is that underpulley really worth it?
Old 10-02-2012 | 11:09 PM
Mrmiata's Avatar
If it won't spin the tires.. I'd look at new plugs.. air filters.. and a throttle reset while waiting on the cable..
Mine is stock other than K&N filters.. and a clown had pulled to the outside of me when I slowed for a car to turn left.. tweaked me a little and running maybe 5-8 mph I nailed her and was smelling rubber...
Old 10-02-2012 | 11:17 PM
falshami's Avatar
think it needs new plugs, airfilters maybe , i mean the car only has 39,000 miles on it , its practically new, i cant even get them to spin off the line with traction control off, though the car is fast,i assumed it was lime a beemer and just would refuse to. maybe a throttle reset?
Old 10-02-2012 | 11:45 PM
Mrmiata's Avatar
Well at that mileage plugs "should" be okay.. filters I would definitely check.. and throttle reset. Turn the key to on position (not start), floorboard the pedal for 5 seconds.. turn key to off.. and leave in ignition..let off throttle and wait 2 minutes.. First time you do it, she will surprise you with the take off acceleration.
Old 10-04-2012 | 07:05 PM
enrikerace's Avatar
is anyone still making an underdrive pulley for us?
check at evosport webpage, go to mercedes w210, and youll find a set of underdrive pulleys.... For the m112 engine!
Old 10-06-2012 | 02:47 AM
falshami's Avatar
how do you knwo what engine you have in it? i know my car is an 04 , with the n/a 3.2l engine , the previous post makes it seem like there were different engines or versions of the engines? im currently in mexico but when i get home , that beautiful machine is getting a throttle reset !
Old 10-06-2012 | 02:50 AM
The post you are referring to is about the Crossfire that is Supercharged. All the engines are the same if they dont have the supercharger, dont worry.
Old 10-06-2012 | 04:23 AM
falshami's Avatar
perfect. thank you aquarilized! is the carbon fiber hood much lighter than the stock one? im considering ways to drop this cars weight! without totally ruining it of course look wise, luckily for me , carbon fiber would match my cars original paint job! sorry not trying to get off topic!
Quick Reply: Eurocharged ECU reflashed
