going with a smaller wheel
Old 08-06-2004 | 07:10 PM
Dan Root's Avatar
Banned
Default
MB is the same bolt pattern ,but check the offset !You will not want a much smaller rear size maybe 1/2- 1" overall max.That won't make that much overall difference.Remember 1" overall = 1/2 " ht difference.Tire width won't make alot of difference.I'm sure you can find a nice combo.
I think if you want a nicer ride you'll need 16 or 17" wheels.
Old 08-06-2004 | 09:56 PM
landho's Avatar
Default
Originally Posted by Dan Root
MB is same check offset ...
the bolt pattern is same as MB, 5x112. The offsets ARE NOT the same. Xfire rear offset is 22mm on 9" wide rim. MB does not use these offsets in the rear... Diff offsets along with wheel width changes will change the track of your vehicle. Which may change the handling of your vehicle...just be aware of these issues.
Old 08-09-2004 | 04:49 PM
stampy's Avatar
Default
Aw, dash it. I've been driving my xfire very spiritedly lately, it's just broken in, and I can't see changing the wheel size anymore especially if it means less grip and road feel. Silly idea in the first place...
Old 08-10-2004 | 10:27 PM
Danwell's Avatar
Default
The wheel wells are made for larger wheels like the stock ones and Im thinking any smaller would look funny. Of course you could use high profile tires but then that would really be heavy.
I love the stock wheels and consider the car a work of art. I would however love to replace the 'plastic' grill and a few other things of that nature but the wheels are perfect for this car.
TerryR
12-13-2019 03:27 PM
Darryl Camisa
10-07-2015 07:10 AM
10-01-2015 01:42 AM
Mackel
09-29-2015 02:41 PM
ritous1
09-26-2015 01:27 PM
Quick Reply: going with a smaller wheel
