Timing fron cover from an SLK 320 2004 compatible?
Old 06-11-2012 | 05:27 PM
jeslias24's Avatar
Default Timing fron cover from an SLK 320 2004 compatible?
Good afternoon, I am new to the forum. Do you happen to know if the timing front cover from an slk 320 2004 is compatible with the Crossfire Limited 2004? Mine is cracked and I am looking to replace it for the least amount. As you know already MB parts are cheaper out there.
Old 06-11-2012 | 08:41 PM
maxcichon's Avatar
Default Re: Timing fron cover from an SLK 320 2004 compatible?
If it is a M112 engine, I can't see why it would be different?
Old 06-11-2012 | 08:48 PM
jeslias24's Avatar
I have been trying to find it on the lists that are on the site but I have not been able to find the exact part. I am barely getting used to the site.
Old 06-11-2012 | 09:16 PM
bigjamesdean's Avatar
Pretty sure these are based of the 1997 slk 320 so as pong as the cover has not been changed through 2004 it shoukd work. Maybe call a service center and see if those are interchangable.
Old 06-12-2012 | 01:04 AM
jeslias24's Avatar
I am buying the part, I will let you know if it fit.
stlas69
09-03-2015 11:28 AM
2004_
07-13-2015 03:04 PM
syfi
07-12-2015 06:59 PM
cx24724
07-12-2015 12:57 PM
2005 Ragtop
07-09-2015 04:16 PM
Quick Reply: Timing fron cover from an SLK 320 2004 compatible?
