CFIRE COUPE rear wheel camber
Old 05-13-2012 | 06:19 AM
GrantB's Avatar
Default CFIRE COUPE rear wheel camber
Question ???
Is it normal the the rear wheels have some camber.... mine do...
Not a lot, maybe about 2 cm in at the top.... ive seen another xf the same.... should i get some sprimg packers to correct this.... or is this normal ????
Will it destroy the EXPENSIVE rear tyres ?????
Penny for your thoughts gents ???
Thanks in advance.
Old 05-13-2012 | 09:04 AM
maxcichon's Avatar
Default Re: CFIRE COUPE rear wheel camber
I think it's 1.4 degrees, rear. 2 cm? (.8") seems a bit much. Do you have stock wheels and tires? Spacers?
Old 05-13-2012 | 09:20 AM
GrantB's Avatar
Default
Just had it checked and both rear cambers are 2.39 degrees
The guys here said that it will wear the inner edges... but in their experience witb normal cornering loads the tyre will wear evenly.... looki g at the wear pattern being totally equal..... im inclined to agree :-)
Regards
Grant B
OTE=maxcichon;672168]I think it's 1.4 degrees, rear. 2 cm? (.8") seems a bit much. Do you have stock wheels and tires? Spacers?[/QUOTE]
Old 05-13-2012 | 10:56 AM
maxcichon's Avatar
Regards
Grant B
[/QUOTE]
Ok, but you may have wear issues. How do the fronts look? Same? Less?
If you do a search here, MikeR (in the states) makes adjustable camber arms. For some reason, (I suspect Germanic engineering arrogance) there is no factory adjustment possible in the rear. There is + - .5 degree available for the front after installation of some "Collision Repair" bolts.
Best of luck!
Old 05-13-2012 | 01:51 PM
MikeR's Avatar
The Crossfire rear camber spec is -0.6° to -1.6°...... your 2.39° will wear out your tires much quicker. I am guessing that is negative camber(-2.39°)...
Old 05-14-2012 | 12:43 PM
Mopar or No Car's Avatar
Get the adjustable rear arms from Mike or you will be sad. If your car is lowered you will definitely need the factory kit for the fronts to get in spec. I did both on my lowered SRT and have absolutely no tire wear problems on a correctly aligned footprint.
Old 05-14-2012 | 01:18 PM
GrantB's Avatar
YEP, you're correct....
However, the wear pattern is totally even across the rear tyres. :-)
Grant B
Old 05-14-2012 | 01:30 PM
Mrmiata's Avatar
If your tires wear more on the inside.. your just not cornering fast enough!
Old 05-14-2012 | 04:53 PM
GrantB's Avatar
Default
Mike's adjustable rear arms ????? Any one got any contact details for these please.... my life is sad enough already ha ha :-).....
No wear issues evident so far tho :-)
Regards
Grant B
UOTE=Mrmiata;672402]If your tires wear more on the inside.. your just not cornering fast enough![/QUOTE]
Old 05-14-2012 | 04:58 PM
Mrmiata's Avatar
https://www.crossfireforum.org/forum...ht=camber+arms
That'll get you in the right direction..
IGot2P
10-24-2023 03:56 AM
maxcichon
04-21-2021 09:29 AM
Bifftws
Racing
07-28-2015 06:31 PM
tom2112
07-28-2015 09:12 AM
Buchacho
07-09-2015 05:13 PM
