Need help. Getting some free Brabus wheels.
But unsure if they fit. They are off an E55 and are real, not knock of Brabus Monoblock II 3 piece. They are coming from a good friend who sold the car without the wheels. They came of a 2003 E55.
The front are 19.8 and the rears are 19.9.5 I believe.
Please tell me these will fit.
thanks
thanks
Re: Need help. Getting some free Brabus wheels.
Grab some H&R spacers and you'll be golden.
IIRC the E55 has a fairly shallow offset in the rear, +35mm I believe.
With the lowering springs and 9.5" wide rears, you'll want to push that out with at least a 10mm spacer... 15 would be aggressive but would be a NICE look, as you should be just flush with the fender.
Besides, you can't beat that price!
Nice score on those...
The monoblock IIs are the wheel that went on every Startech crossfire sold in Europe. It looks like five tuning forks. You can see it in the Startech press shots.
2005 Startech Chrysler Crossfire
Its the wheels in the pics at the link above.
Full lineup:
WHEEL COLLECTION - CEC - Claus Ettensberger
I'm glad you're getting the V's and not the II's, the Mono-II is a bit dated
Originally Posted by FP
I think 12mm in the rear and 10mm spacers in front would work perfect. Dont forget to get the longer bolts.
The rule of thumb Maya is to add as many mm to the bolt as you are to the spacer.
before you get all excited im going to burst your bubble. the e55 uses a 14mm diameter lugbolt and the xfire uses a 12mm lugbolt. you will need to source shanked lugbolts that have a cone seat and thats a tough find. i bought superlight wheels for my 32 and they wouldnt fit due to the larger lugbolt holes. sorry
Originally Posted by Mrmiata
Hub swap an option? Havent dug into our axle setups.. just popped into mind after Jedi Killer.. LOL..
Accuracy would be really be required though and done on a mill, no hand drilling.
