1-2-3-4-(crunch)5-6
Old 11-03-2011 | 06:51 PM
Chris L.'s Avatar
Default Re: 1-2-3-4-(crunch)5-6
Originally Posted by tighed1
Been there done that a couple of times.
Not on my Crossy though. 167,000+ miles and she shifts just fine!
That's cool....167K....Doesn't the owner's manual say you shouldn't have to ever change the lubricant?
Old 11-03-2011 | 07:16 PM
Yeah, but they want to sell you a new gearbox once in awhile. LOL
I'd change it, god alone knows what crap is floating around in it.
Old 11-03-2011 | 07:28 PM
John, I would try, as a last ditch effort, change the fluid. But I think you have something going on in their that shouldn't. I saw a new listing on eBay for a trans with 5K miles on it, delivered to your door $1000. That is a tough number to swallow.
Good luck on how ever you decide. James
Old 11-03-2011 | 08:01 PM
RODNEYRAEL's Avatar
I would also flush the fluid in the clutch master and the slave cylinder. I bet it's going to need a clutch. If you flush the fluid in the master and it improves or goes awy the clutch is wasted. Buy the way mine is a auto and I'm thinking yours is hydraulically assisted not the old school cable?
Old 11-04-2011 | 05:29 PM
Chris L.'s Avatar
Not an issue ....LPW !!!.....
Old 11-04-2011 | 05:35 PM
I thought the linkage was self adjusting.. it sounds like a synchro to me.
I can't imagine any linkage being self adjusting, especially if you see him drive....lol... bottom line here is, unless it gets to the point you can't shift, I would drive it. You don't know how many vehicles I get drive at my position now. None are the same. Some have clutch problems, linkage problems, synchonizer problems, but all are getting by. He could have chipped a tooth so to speak, and when it is in rotation, it will grind for a split second...but it will run for a long time just like it is...an annoying yes, but it will be fine...drive it for awhile and see if it gets worse, and quit missing shifts...lol
crossmember
08-22-2014 12:30 PM
waldig
04-26-2014 06:19 PM
Spudracer
05-20-2012 07:19 AM
milkjuggz
10-05-2010 11:31 AM
ohnoesaz
07-22-2010 11:52 AM
Quick Reply: 1-2-3-4-(crunch)5-6
