Testing vacuum pump-central locking system
I have a 2005 SRT and when I use the key fob to lock (or unlock) the car the only lock that works is the driver side. The hatch, the gas door and passenger door remain open. Also the switch on the console does the same thing. I pulled the vacuum pump of the central locking system from the back of the car. My question is does anyone know how to test it? The three little plastic nipples (attached to yellow lines are all supposed to emit air when locking correct?? I took the housing that holds the 2 lines off and hit the lock function on the key fob. Only one of the nipples emits air. I don't think I have a vacuum leak anywhere ...I really think it's a bad pump, but before I shell out $400 for a new pump I would like to be able to test the one in my car. I've checked fuse #9 in the fuse box...it's good. Any help bench testing this unit would be appreciated. vr, Lee
Re: Testing vacuum pump-central locking system
The lines can get brittle and break the most common is the hatch lock on coupes.
You say you took the housing off that holds two lines, do you mean the manifold with three lines? I am sure that it is fed underneath by one port for air and one vacuum port.
If you took of the three hoses from the manifold each one would blow or suck. Only by doing this would you know that they at least were working. In which case you probably have broken air lines somewhere.
Here is some pictures.
https://www.crossfireforum.org/forum...tml#post491510
180 thx. I just happened to notice that my car was not locked on the passenger side one day about a week ago. Yes I do mean the manifold with three yellow lines. There is a black clip that hlods it on to the main body. When you say they would all blow or suck do you mean they all would do the same thing (blow perhaps if I went to lock or suck if I were to unlock) Or are they independent and one might blow while two might suck for example? I jus made the assumption (maybe erroneously) that all three would do the same thing depending on whether I was locking or unlocking the car. I really hear no hissing noises that I keep reading about which may or may not mean anything. However when connected the driver door locks and then the pump times out after 10 or so seconds. Thanks much!
180 I just re-read my post. I want to make it very clear (the question I'm asking). If I were to hit the lock feature on the key fob would all three lines suck? I have to assume they would (or perhaps all 3 would blow)...anyway they all would do the same thing for a given function correct? Once again thanks for the info. I've been a member here actually for over 4 years but rarely if ever post, but really need expert help on this one to make sure I do it right.
Is the manifold divided into two sections?
A pump will suck on one side and blow on the other, just like a vacuum cleaner. It is possible that this suck and blow system is used, that way it does not have to blow so much air to operate two locks and uses the other side to suck the other two locks.
In this case one port will suck and the other two ports will blow. On the other cycle that one port will blow and the other two suck. Locking would be done by vacuum on two locks and air pressure on the other two. I would think that the two door locks are using air pressure and vacuum the same way. They are similar, while the hatch and gas cap are different locks.
If the manifold is not divided then all three ports will either blow or suck.
One air line must be teed off somewhere, I suspect the gas cap and hatch locks. This would be the line that is separately operated if there is a divided manifold, I guess. In which case the latch and gas cap would fail at the same time if that hose broke. But no one has mentioned that, so it's just a guess.
If you test for blow and suck by removing the hoses from the manifold you could find out what the system is doing and possibly find the fault.
Have you opened the unit? There may be a leak inside it to one or more ports.
Still not fixed. I voltage tested the #2 and #4 cavity on the CLP/SSM and both had 12 volts of current. So if I read the diagnostics portion of the repair manual correctly it is saying replace with a new CLP/SSM and all should be good. I still want to check the vac line on the bend at the hatch to make sure there is no leak there. If there is a leak I should be able to hear it, right??
If they are OK then the problem lies in the lines or locks.
Looking at this diagram (Thanks Rekcah) it shows the module either blows or sucks all three at the same time so if when testing it, all three should do the same thing. Looks like a module not doing what its supposed to (to me). Search for a less expensive one they are out there.
One last thing! Did you try hitting the lock/unlock button twice? I understand (from somewhere deep down in my grey matter) that you can set it up to lock/unlock in stages. Anyone else remember this or have a different take on this?
That top part is a manifold and there are two ports at one end and one at the other, this is a hint that the ports operate separately on the pump. I cannot be sure of that but the operation would be quicker using a smaller pump. I have asked the OP to confirm how but there is no response on this question. Sometimes answering a question can help with the solution.
The remote can be set up in two modes, all doors and hatch or driver door with one push and the passenger door and hatch with a second push.
Well not sure how to answer this but here goes. When I tested the CLP/SSM only one line responded at all with pressure. If there was indeed a vacuum on any it was negligible. Yes I know about the key fob and that you can set it up two different ways. That is not the problem. I have not yet opened the unit. When I drive the car the drivers door will lock like it should however the other door does not lock (ie when reaching 5 to 10 MPH). I can hear the pump run for a while then it stops after time out. Pushing the key fob I can get the driver door to lock and unlock but not the passenger door the fuel door or the rear hatch. Those 3 remain unlocked no matter what.
If you look at the diagram you will see that the center yellow line goes to the drivers door. If you can disconnect the other two lines you should be able to see if there is a vacuum or pressure when you select lock or unlock. If you lock the doors and either blow or suck on each line That should lock or unlock the other door and trunk and gas door. It should also show if one of them is leaking. Good luck
Could you explain how your reading of that diagram explains the blow or suck cycle? The two doors are on opposite ends of the manifold, so one could be suck and the other blow, this may help if you want to open the doors on a separate cycle.
Just my $0.02 worth.
Ok I've tried the CLP/SSM testing as best I can tell it is malfunctioning. After about 4 hours of research I found a ned MB unit for about $390. If my original pump is working it is negligible (except for the drivers door). When I get the new pump in I'll post the results. Thx all
Replaced the CLP/SSM...still no luck. I've also checked both relays under the main fuse box top. The black one is TYCO 002 542 21 19 the yellow one is TYCO A002 542 14 19. Both are working, you can actually feel and hear them click when you depress the lock/unlock on the key transmitter. The last part I guess I can change is the SKREEM then it will be dealership time (which I absolutely despise because for every problem they have fixed they have caused another). If anyone has any other ideas I certainly would appreciate them. Thanks!
