Tire pressure Light
Old 08-20-2011 | 07:02 PM
maxcichon's Avatar
Default Re: Tire pressure Light
Sounds like you hit the (+) 10%!
Old 08-20-2011 | 11:04 PM
Larry Hitze's Avatar
If the battery finally dies in one of the senders, the light comes on and stays on.
I THINK the light comes on if the pressure in any tire goes below 25 or 26 pounds. I also believe it comes on above 38 or so pounds, but I'm not sure. (Mine came on at the Dragon a year ago, one tire was down to 24 and others were around 29).
The standard pressure is 34 or 35 psi, if your tires went down to about 30, I don't think the light would come on. I don't know if a dealer can read what sensor has failed or not.
The base models had no TPMS, and I wonder if that is why one car was destroyed at the Dragon last fall. I have always wondered if he didn't have a soft tire - with his car being a base model, he'd have no warning, and the accident played out like there may have been a soft tire that made a bad combination with tall, wet grass.
GET IT FIXED.
Pizza, Mine says the correct pressure is 33 in the rear and 32 in the front.
Old 08-21-2011 | 08:23 AM
6000rpm's Avatar
I found in my owner's manual that the light will come on when a tire is 25% low, not 10%???
File Type: png
Old 08-21-2011 | 08:27 AM
maxcichon's Avatar
I went and looked-you're right. I don't know where I got 10%-I'll plead the 5th on this matter.
BUT, mine have tripped at 29 psig all 3-4 times it/they've gone low.
I dunno.
Old 08-21-2011 | 08:44 AM
TiredRetired's Avatar
Mine have never come on from -30F to +96F. I seem to recall the previous owner saying that he had the tires filled with nitrogen but I cannot be sure of that. Not even sure what difference that is supposed to make.
Old 08-21-2011 | 10:16 AM
Kodebuster's Avatar
Everything you ever wanted to know about Nitrogen Vs Air...:
Tire Tech Information - Clearing the Air About Nitrogen Tire Inflation
Bottom line, if your running at a Track, go nitro, if your running normal, save your money and buy a good tire gauge...
Old 08-21-2011 | 07:27 PM
Good info!! Thanx for sharing that.
Kodebuster
11-05-2020 04:06 PM
PimpDaddy
09-29-2016 11:55 PM
Bifftws
Racing
07-28-2015 05:31 PM
axnguyen
07-21-2015 11:41 AM
Blackout317
07-07-2015 08:38 PM
Quick Reply: Tire pressure Light
