cleaned my engine
Old 07-08-2011 | 05:17 AM
Default Re: cleaned my engine
Originally Posted by OldSalt
What is CD-2 not familiar with this product/
OldSalt
It is a topical treatment for use in detailing an engine bay. Comes in an aerosol spray can; silver with a black top. Product seals components under the hood and keeps out dirt & water. Just need to make sure you get the engine clean first.
I use Greased Lightning Shop & Engine Degreaser. Product has been the best yet I've used. Comes in a purple pump spray bottle. What I like about the product is that it starts attacking dirt & grime right away. All I have to do is rinse it off using the fan spray setting on my water nozzle. No real force is required when rinsing the engine bay. Keeps the electronics exposed to minimal moisture.
Old 07-08-2011 | 08:21 AM
For me the difference in getting a "satin-like" look is to wipe off the excess after allowing it to set-up for 5 minutes and then taking a drive for 15-20 minutes to dry out the CD-2. The spray can says to wipe off any excess after the drive & heat-set of the CD-2. Following the can hasn't produced acceptable results for me in the past. That's why I stopped using the product. Bob's procedure worked for me.
I was not trying to be a smart ***, I am glad this way works for you, but I get the same results by following the procedure on the can, and my engine bay does not look like someone hosed it down with astroglide
Old 07-08-2011 | 11:27 AM
Quit worrying about it. I never took your comments as being other than simply stating that you followed the can instructions and got similar results.
For me, it didn't work in the past. Keep in mind, when I used CD-2 on my Merkur XR4Ti's, these were non-intercooled turbo engines and that might be too much heat setting for CD-2. Always turned yellow and made the engine bay a mess.
Old 07-08-2011 | 06:47 PM
bmorgan's Avatar
The F-150 turned out great. I am glad my procedure has helped some of you. I absolutely love the stuff, and will use nothing else.
OldSalt, you should be able to find CD-2 at AutoZone. It is a TurtleWax product. They quit selling it for several years.... Something to do with PETA complaints Anyway, they must have figured out how to get around whatever their complaint was, and began selling it again about a year and a half ago.
Old 07-08-2011 | 06:58 PM
Mike1118's Avatar
Geez.............1st it was clay bar.........now CD2. Where have I been? Anyways, I managed to buy the last can of CD2 at my Autozone tonite. Man the world has changed since my Lions Drag Strip days.
Old 07-08-2011 | 07:27 PM
DBLewis's Avatar
I have yet to see a Crossfire with both grommets installed from the factory. Did you notice the hole was off center? I believe that is why it was left off.
James
Mine is off center and missing, too.
I figure someday i will get one on there and get it to fit....
-Dave
Old 07-08-2011 | 07:31 PM
DBLewis's Avatar
hmmmm.... astroglide.........
interesting subtopic this could make for the forum....
101 automotive uses.....
make that 100 and 2!
-Dave
Old 07-10-2011 | 10:09 PM
Originally Posted by bmorgan
CD-2 is the best. I will never detail my engine without it.
I fully agree with ya here !!!
Just did mine a few weeks ago........
Old 07-10-2011 | 10:39 PM
bmorgan's Avatar
Gary..... That looks awesome. What did you do..... suspend yourself from the ceiling to get that shot? Absolutely beautiful engine bay my friend.
Old 07-10-2011 | 11:40 PM
Thanks...I actually was up on a step ladder for that shot...LOL
Old 07-11-2011 | 08:14 AM
bmorgan's Avatar
Well, some people would think that getting up on a ladder to take a picture of your engine bay on a daily driver would be a bit obsessive........ But, I like the way you think.
PNA
11-12-2020 04:44 PM
PimpDaddy
09-29-2016 11:55 PM
reiji
10-15-2015 10:50 PM
Indelibility
08-27-2015 10:21 PM
Rusty475
07-13-2015 10:03 AM
Quick Reply: cleaned my engine
