Needswings has the Wavetrac for crossfires. '04 to '08
Old 06-28-2011 | 09:30 AM
Default Needswings has the Wavetrac for crossfires. '04 to '08
Needswings now has the wavetrac for all Crossfires 2004 to 2008
The Wavetrac is the carrier in the differential , all the axles fit into the diff N/A or srt the 2004 to 2009,,The 04 crossfire has axles stubs,,( this is where things change) the axle stubs from a crossfire or slk have to be sent along with your differential to ( call Rob at Needswings,he will have the info on where to send you diff. They will modify your axles so that it becomes a pushing in and out type like the srt6 , Rob will return your C-clips and your diff with the axle stubs in it ,you may pull the stubs without removing the rear cover, to install the diff into car,or leave them there.
Now for the c-clip,,it is used in the 2004 Crossfire and some Mercedes when unitrax gets you diff and axle stubs they machine about .020 out of the grove on the end of the axle so a spring clip will fit this will alow the axle to be a push in type like the other Crossfires are now. if you ever decide to remove the Wavetrac to sell it or what ever, you should swap the axle stubs with whomever you sell it to if they have a SLK or an 2004 Crossfire, this way they can install and drive and so can you. if you sell it to a person with a 2005 and up you can reinstall your C-clips and reinstall your axle just as stock ,, now all you need to do is call Rob at Needswings he has instructions on how to get the differential sent in and back to you with the Wavetrac installed in it, find a mechanic that can do the install or do it yourself , call Needswings for prices.
Call Rob for any info you may need on this. jim
Old 06-28-2011 | 10:01 AM
Default Re: Needswings has the Wavetrac for crossfires. 04 to 08
FYI, my '04 is build number 4x006237 and it has one piece axles, no bolts.
Old 06-28-2011 | 04:49 PM
you can buy the Wavetrac from Needswings and he will tell you where to send your diff. you do not need to send the axles just diff. jim
Old 06-28-2011 | 04:52 PM
I just wanted to say that not all '04 Crossfires have bolt in axles.
Old 06-28-2011 | 05:28 PM
I just wanted to say that not all '04 have bolt in axles.
thank you i did not know that
now do all 2004 crossfire's have bolt in axles??
Old 06-28-2011 | 05:30 PM
tighed1's Avatar
Default Re: Needswings has the Wavetrac for crossfires. '04 to '08
Guesstimated price? Didn't see it on the website.
Old 06-28-2011 | 05:34 PM
32krazy!'s Avatar
jim he is saying he DOESNT have the bolt in axles on his 04.
i think everyone should also be aware that theres still over 20 units that have to be built for the g/b before any are sold outside the g/b. (at least they should build ours first). mine has been in cali since fri. and im still waiting for a call to tell me its done and make the final payment
Old 06-28-2011 | 05:46 PM
Originally Posted by 32krazy!
jim he is saying he DOESNT have the bolt in axles on his 04. yep i got that , i am also saying any crossfire with any type axles can get the wavetrac installed in their car.
you are correct,,, Needswings will not have the wavetrac until all the first group have received theirs, and that should be soon, i hope, i was told 2 to 3 weeks. jim
Old 06-28-2011 | 06:02 PM
I am not in the immediate market for this diff, I am just trying to offer up info for future reference to help others. Take a look at my '04.
Old 06-28-2011 | 06:04 PM
32krazy!'s Avatar
james i think you hit the nail on the head. instead of going by yr and model just climb under the car and look. if its like yours no mods. if theres a flange with bolts the stub needs machining
Old 06-29-2011 | 03:23 AM
Mimi05SRT6's Avatar
What's the usual downtime, say about a week? Taking it off, sending it to Needswings, getting it back and reinstalling.
Old 06-29-2011 | 06:43 AM
yea a week to ten days should it.
Old 06-29-2011 | 07:18 AM
32krazy!'s Avatar
fedex'd mine to cali from tn in 4 days. takes 24 hrs turnaround time IF they have the wavetrac in their hands then 4 days back. mine has been there since fri morning and havent heard from them yet
Old 12-30-2011 | 04:50 PM
sk8erjosh09's Avatar
I just came across this post and sorry to revive it a half a year later but I just went out and slid under the car to see if I had the flange you mentioned. My build date is 04/03 last 6 of vin is 000135 and mine is exactly like the pic James took. So that means if I were to order one that it would only be a matter of putting it in right? I dont need to ship my diff anywhere?
Old 12-30-2011 | 05:12 PM
you are kinda right ,,if you buy your wavetrac through Needswings and want to be sure of the warrenty just incase the factory says it was installed wrong ,,,again if something happened to it. (he has a cheaper price) he would tell you where to ship it too,
mine was done by Needswings/and wavetrac builder and i am running a V8 i really don't think anyone will have a problem with the wavetrac unless it is installed wrong,,,not tring to scare you buy they do do a good job.
now if you have a GOOD mechanic or can do it yourself then yes,,buy thruoghl Needswings,, and install yourself. jim
Old 12-30-2011 | 05:26 PM
Thanks for the reply, I still have 6 months or so before I would do this so I have time to sit on it and research if Im capable or not.
Old 12-30-2011 | 06:59 PM
I wish you guys were closer. We can do the whole setup in a day. $400 out the door for install only. You supply the parts. If we had more, the price could be lower, but we have to shut the shop down in order to go thru the whole process uninterupted and get you on the road the same day.
Old 12-30-2011 | 09:22 PM
LantanaTX's Avatar
this on my list but starting from the key with a 55K ECU and Turbo is coming first along with a trans and diff. I hope to have all this done before the next fall Dragon. I looked under my car and do not have the bolt on axles. My '04 was built 01/04
Old 12-31-2011 | 02:34 PM
That is too bad. That's a good price. I figure if needswings has got a real good set of instructions I should be fine.
Old 12-31-2011 | 03:02 PM
32krazy!'s Avatar
if your in cali then have unitrax do it. 225$ is the install price. drop it off and save the shipping. they are the direct distributor for the wavetrac and do these diffs in 24 hrs.
