esp/bas light coming on
Old 05-26-2004 | 11:36 AM
BBROWN's Avatar
Default esp/bas light coming on
Has anyone had a problem with the bas/esp light coming on? Mine comes on randomly and then applies abs to the front left brake for a split second and then disables itself for the rest of the car ride. It can be scarry when the light comes on doing 65mph, jerks the car. Took it in for service and they say they have fixed it this time. Guess i will find out after lunch when i pick it up. They told me it was a loose connection. Wanted to know if anyone else had this problem and if so what the fix was.
Old 05-26-2004 | 11:44 AM
pageoneresults's Avatar
Default
Hmmm, the only time I've seen that light come on was just recently after an Upsolute ECU Upgrade (battery disconnect). To clear the error...
Start vehicle > leave in Park/Neutral > Turn steering wheel all the way to the left and hold for 5 seconds > Turn steering wheel all the way to the right and hold for 5 seconds > Then bring it back to center > Light should go off
That should clear the error. Why it is coming on doing 65 is definitely scary!
Old 05-26-2004 | 11:45 AM
DFWSBR's Avatar
Default
Only time I had that light come on was after I connected the battery. Loss of power will put it into "learn mode". After driving a block or so, the light goes out and never comes back
Your situation sounded more like a wiring issue. If they said they found a loose connection, that should do the trick.
Old 05-26-2004 | 02:20 PM
BBROWN's Avatar
Default
THEY FOUND THE PROBLEM. IT WAS A BAD SENSOR AND IT WAS REPLACED. THANKS FOR EVERYONE'S HELP. IT WAS SCARY, IF IT WASN'T ON WHEN I STARTED THE CAR IT WOULD COME ON RANDOMLY AND THAT IS WHEN IT WOULD JERK THE CAR WHEN YOU DON'T EXPECT IT. HOPEFULLY THIS WILL DO THE TRICK.
Old 05-26-2004 | 02:30 PM
WesMichaels's Avatar
Default
Could be real fun on I264 in a pack of traffic @ 70+. Glad they got you fixed up.
PNA
11-12-2020 05:44 PM
Hoppy
12-07-2018 08:36 AM
wruss
02-08-2017 02:05 PM
northwest_crossfire
05-30-2016 06:19 PM
RiderJC
08-04-2015 11:25 AM
Quick Reply: esp/bas light coming on
