Seen the "Sticky Ignition fix" But...
Re: Seen the "Sticky Ignition fix" But....
Once I got the dash torn apart, and loosened the bolt, I could make my key turn!
Seems like the jarring around of the assmebly as I tore the dash apart did it.
If it's not the case for you, look in the instructions for "if you key won't turn".
User "CaptDave" here went thru this about two weeks ago, you might PM him for advice. I talked to him
on the phone a few times during the process, he got his fixed!
[QUOTE=rekcah]it's explained in my pdf in the sticky ignition thread.[/QU The reason your key will not turn is because lint from your pocket gets on your key a small bit at a time. wash it out with a lot of wd 40 wiggle the key till turns and it will. Then take it a part clean the lint out. i do this several times a mounth in my key shop a22roy @aol.com
tcar32909
08-01-2024 02:41 PM
Pacemaker
28
08-16-2015 07:33 PM
