Weird engine noise! *Video inside*
Well, for the last 2 weeks or so, a weird noise coming from the engine. I literally have no clue. I spent a lot of time just looking for where the noise is exactly coming from, and I couldnt figure it out. All I know is, it is coming somewhere from the top part of the engine.
I tried to video tape it, and you can clearly hear this unknown noise, however, it is clearer in person. Towards the end of the video, the sound goes away completely.
P.S. The car operates normally, NO codes on the dashboard whatsoever, everything seems perfectly normal while driving or idling.
Any toughts??? Here is the video:
http://www.youtube.com/watch?v=HsE6jPz-EzU
Re: Weird engine noise! *Video inside*
YouTube - Weird noise from the engine
I have had bearings that did that, noise and then nothing. If one finally seizes you'll need a new belt and a tow job.
Release the belt tension and spin the pulleys.
It's too dangerous to do the screwdriver to ear trick though.
My guess would be a bearing in the idler or tensioner. Or even one of the other bearings is highly possible.
PS I had to call Rob at Needswins for a pulley saver kit due to the fact that the pulley is on back order.
Thanks guys. My inital thought was that it was coming from a pulley. However, when I lean towards the left side of the engine, I hear it, and when I lean right side of the engine, I hear it. If it was a pulley bearing, dont you think I could clearly hear where it was coming from?
This is strange, The noise is there, coming from the engine, I look right at it but yet, I cant figure out where it is coming from.
massanu
18
11-23-2015 08:52 AM
velociabstract
15
09-07-2015 03:43 PM
