Pleeease!!! I want my car back
Re: Pleeease!!! I want my car back
Maybe the earlier Crossfires won't do it. But my 06 roadster and 08 coupe, as well as my 06 Jeep Commander will all shut the lights off if I leave them on or leave a door open. It takes a little time, maybe 15 or 20 minutes but it should never drain a battery.
I recall having a bad alternator diode (high leakage rate) that drained the battery overnight, I think it was on my 1970 Dodge Charger.
When I bought my used '05 Crossfire, it was still under the original warranty. The warranty stated that a loaner would be made available during the first 36000 miles/3 years. I never used the warranty.
It would be nice if we had the definition of what a 'several hours' is.
Is it two or twenty? Knowing would help. If its two hours what ever is using the power would be pretty warm.
If you start with a boosted car, run it and then park it and its flat in an hour or so what is there to say that the battery was ever charged enough in the first place, maybe an alternator problem, starter shorting out.
REST motor continually running, other motors running continuously, fuel pump, solenoids jammed.
Basically after 5 hours, i know it is more than two. I came out of my college class which takes two hours and the car turned on fine.
onehundred80, the several hours its about five i would say. since a tested the car after two hows and it turned out fine.
I believe i will go to the dealer and start doing the "fuses trick". I'll make sure to do the beer googles thing in order to make thing look better lol.
Thank you very much for your help guys i will leet you know when i bring my car back.
Originally Posted by oledoc2u
Pizza, you have got to get a life buddy.....I am going to take up a collection for an escort for you....lol
My lights don't shut off when left on, so what am I missing here?
Guys i finally got my car back (with the same problem though) from the dealer so i will start checking the drain myself. I just thank god i didn't have to pay a cent. I got my multimeter, but in order to begin i should know how much current should the crossfire read without a drain (which current number am i looking for). Ive already seen verious videos on u-tube of what i have to do, so ill give it a try.
And another thing, in the case i found the fuse related to the drain, where can i find the car's wiring diagram? This will be very important if i want to find the specific spot of the drain.
Thanks alot guys!!!!
Crossfireone
06-05-2015 03:16 PM
