Purchased 2004 18,000 miles service what???
Old 09-14-2010 | 11:22 PM
mdotoli's Avatar
Default Purchased 2004 18,000 miles service what???
Hey everyone, i just purchased a 2004 Crossfire 18000 miles, what do i need to do first with service? Oil change? Air filtter? Battery Life? Breaks? Any suggestion what i need to lookout for will be GREAT..
Thanks
Mike in North Carolina
Old 09-15-2010 | 12:29 AM
magneticred's Avatar
Default Re: Purchased 2004 18000 miles service what???
If you don't know when the oil was last changed, I would certainly do that. The FSS can assist you in knowing when to do subsequent changes. If the air filter looks clean it may have been changed already, otherwise a new one would be wise. Also consider changing the cabin air filter. The brake pads should be easy to check, and unless driven hard should have life left. I don't know how old your battery is, but when the battery starts going bad strange things are known to happen with these cars. It would not be unusual to need new wiper blades.
Lastly, welcome!
Old 09-15-2010 | 12:46 AM
tighed1's Avatar
Hey Mike welcome to the Family!
As mentioned the FSS will tell you when it's time for an oil change. A lot of folks here change oil before the FSS says to as a special treat to a special car! You will find that an oil change is expensive when compared to other cars.
Brakes get changed early cuz folks get tired of all the dust from the stock pads.
As far as suggestions, I'd say start reading posts here on the forum related to any questions you may have. TONS of info here. Here's a post with ducumentation on the car. Read it for more info than you can retain!
LINKY
Enjoy the car! (It is Graphite (Grey) I hope.)
"See" ya on the Forum!
Old 09-15-2010 | 09:18 AM
Chris L.'s Avatar
There are 2 air filters, owner's manual says change at 60,000 miles. I replaced the ones on my 07 at 33,000 & in retrospect should have waited longer....they really weren't that dirty.....maybe because there is about twice the filtering area as most cars I've been used to???
Old 09-15-2010 | 11:33 AM
BP11's Avatar
Default Re: Purchased 2004 18,000 miles service what???
I always do the oil first because if you put 0w-40 in it from now on you know your running the right oil. Who knows what the dealership or the previous owner put in there. Oil filter too, and you can do the air intake filters which don't hurt anything I assume people are going to suggest you get K&N's though and I would suggest that myself.
Old 09-15-2010 | 09:03 PM
maxime75us's Avatar
How much did you pay?
Tires maybe ?
try the Continental dw or dws
check all fluids. trans fluid??
Air intake filters can be clean or dirty, mine were bad at 22 when i bought it!
this is it!!!
on the manual they advise a few things to be checked since it is a 2004. read and act to keep your a long time.
my best
Old 09-15-2010 | 09:19 PM
Balashi's Avatar
I also have joined the new used Crossfire Family. 2004 with 7800 miles, still new
Enjoying every new mile I put on it!
Old 09-15-2010 | 10:31 PM
mdotoli's Avatar
How much did you pay? Payed 16k for it
Tires maybe ?
this is it!!!
my best[/quote]
Old 09-16-2010 | 09:13 PM
+fireamx's Avatar
First, welcome to the Forum Mike.
You didn't say if it was a 5 or a 6 spd. But if it's a 6 spd. some service techs recommend changing the manual transmission fluid from the factory installed ATF to a synthetic motor oil.
As Tigh pointed out, changing over to "Dust free" brake pads is highly recommended. I used Rotex Gold, and didn't change mine until I had 30k miles on my car, and could have kicked myself for not doing it sooner.
Watch out for that automatic "Dimming" rear view mirror, it makes it very easy for a LEO to sneak up behind you at night.
I've found the traction control to be a little more sensitive in my 04 than it seems to be in later models, but that just might be a problem with my car.
If you notice the TC intruding on your "normal" driving there is a way to circumvent the problem, (at least on the 6 speeds). Just PM me for details.
Good Luck with your new 04.
pioneer4x4
07-21-2015 02:13 PM
axnguyen
07-21-2015 11:41 AM
skeet370
07-18-2015 01:02 PM
KwehCat
07-16-2015 04:48 PM
Rusty475
07-13-2015 10:03 AM
Quick Reply: Purchased 2004 18,000 miles service what???
