Sprint Booster
Old 09-10-2010 | 03:56 PM
dinasrt's Avatar
Default Re: Sprint Booster
Originally Posted by Musclefan21
Tried to install it yesterday but it was unsucessful. I can clearly see it is a piece of cake to install "IF" i could get that washer out. Autozone didnt have a small magnet to get the washer out so I gave up and put everything back together. I will find a small magnet that will fit to that hole to get the washer out and post results today. Can't wait
Hey Musclefan. When I did mine, I used a standard pair of tweezers spread open and it snatched that washer out cleanly. Just like the old OPERATION board game we played as kids. You're going to enjoy that increased throttle response!
Old 09-10-2010 | 03:58 PM
Bigkid's Avatar
I agree with Franc. Once you test drive it the SB will not be for sale. I have one on both my cars and love them. I was thinking about up grading to the selectable model on the coupe. Has anyone had both and do you think the upgrade is worth it?
Old 09-10-2010 | 04:08 PM
dinasrt's Avatar
I only have the experience w/ the newer selectable. What I like about it is that my wife and I both drive it, and the race mode is a bit much for her and she prefers the sport modes driveability better.
Old 09-10-2010 | 04:09 PM
ink pen style magnet, most auto part stores have them...did my last one in 10 minutes...lol
Old 09-10-2010 | 04:27 PM
rfors777's Avatar
I think you should upgrade yours, and sell me the original!
Old 09-10-2010 | 04:34 PM
Beaner's Avatar
I put mine in without loosening the bolt for the gas peddal. just make access for your hand to get in there and install by feel. It only goes in one spot and one way so you wont mess it up. Who needs to see what they are doing
Old 09-10-2010 | 04:35 PM
only one way....are you sure....
Old 09-10-2010 | 04:43 PM
As I recall you can connect it either way but only one way will make it work.
If you connect it the opposite way you won't have any throttle response at all.
That is what happened to me originally.
If this happens simply unplug it and switch it around the other way and reconnect it.
Old 09-10-2010 | 05:02 PM
you see beaner....you got lucky again.....
Old 09-10-2010 | 07:39 PM
Musclefan21's Avatar
Just installed it. 5 minutes job. OMG!!!!!!!!!!!!!!!!!!!! I cant believe how sensitive it has become. I broke the tires lose multiple times. Throttle response is unreal. I predict I will be in trouble during winter Great mod!!!!!
Old 09-10-2010 | 08:26 PM
shapeshifter309's Avatar
Tempted to put this on my list of things to buy for my XF, although I'm worried that it would:
1. void parts of my warranty, or that Chrysler would try to if they found out it was on there.
2. be illegal for stock class autocross racing.
3. at some point fail and leave me either with a throttle stuck wide open or unresponsive. God forbid I would be in stop-and-go traffic.
Feel free to prove me wrong on any of those counts.
Old 09-10-2010 | 08:48 PM
It is a small electronic part behind your gaspedal which nobody will ever see unless they are actually looking for it. Even then, it will look like any other electronic crap so they will need to be looking specifically for it. so your warranty would be fine and no, it would not be illegal ofr stock autocross racing. They dont need to know...
About failure.. Let's say it did fail. Simply unplug it and plug the stock wire to the gas pedal like from the factory (5 minutes). Go on your way.
You are over-analyzing this.. Just get one and enjoy.
Old 09-10-2010 | 09:01 PM
Bigkid's Avatar
That could happen. I will let you know if I decide to go for it.
Old 09-17-2010 | 10:34 AM
TomStratRT's Avatar
Okay, I have tried the tweezer trick...didn't work. I have tried a magnet...didn't work. Why the hell did they put the washer in there in the first place??
It seems like the center part of the washer is the same size as the piece it sits on. It just won't come out!
Old 09-17-2010 | 10:53 AM
dinasrt's Avatar
It is a bit close but it will come out. Most autopart stores have a telescopic type magnet or pen style, and would work for you. I couldn't find mine and used straight tweezers spread open. You have to go very slow and precise; like the boardgame "OPERATION" we use to play as kids. It worked for me on the first try. I should have become a surgeon right.
Old 09-17-2010 | 12:25 PM
downwardspiral's Avatar
Keep the pedal on!! There is an access panel on the side of the console with 2 dinky screws holding it on. The gas pedal cable is right behind that panel, and it takes alot less effort than taking everything apart.
Old 09-17-2010 | 01:25 PM
TomStratRT's Avatar
Well, I finally got it out. What a ***** that was! I replaced the washer with one that has a slightly larger opening in the middle
Sprint Booster is now installed and everything tests out fine. I'm not going to go into an extensive review because frankly, it's all been said before.
In green mode, you get noticeably faster acceleration.
In red mode, it's twice as responsive and not for every day driving for sure.
Worth every penny.
Now if only I can figure out why my brakes are squealing when I go in reverse...
  #38 (permalink)
Old 09-17-2010 | 03:14 PM
Worth every penny.
I will take mine apart and do a clear DIY just for future refences as soon as I get a chance. Very easy job.
Mine is NOT for everyday use. It actually started to get on my nerves that I cant take off normal most of the time. Damn thing feels like I floor it each time i touch the pedal to take off. I need to learn how to drive again... LOL
About break squaling when in reverse... Time for new pads and get those rotors machined befoere putting new pads on. Or new rotors...
  #39 (permalink)
Old 09-17-2010 | 07:16 PM
TomStratRT's Avatar
Finally got to take it out for a nice long drive. This is how the car should have accelerated from the factory. As if it wasn't fun enough to drive before, it's that much better!
  #40 (permalink)
Old 09-17-2010 | 11:01 PM
If it seems to sensitive then you probably want to go with the new adjustable version of the SB.
As for directions of how to install with photos it has already posted here
Quick Reply: Sprint Booster
