Oil Change Mistake With Pictures! Help...
Old 09-05-2010 | 06:08 PM
Default Re: Oil Change Mistake With Pictures! Help....
Originally Posted by blackcrossfire07
Thanks guys. I feel much better now that I put the washer on. Only took me 15-20 min at the most.
Next time, you might want to consider the topsider method as recommended by MB. I use the same setup as MikeR's and it's super easy. Here's his write-up: Oil Change Made Easy
Old 09-05-2010 | 06:21 PM
blackcrossfire07's Avatar
I don't think i really needed to put the washer on but i feel better knowing it is back on there. It would take a lot to get our oil bolt to drip oil. The bolt is long and it didn't start leaking until I completely removed the bolt. It would take a lot for that bolt to fall out on its own.... I don't think it is possible. The only risk of a problem is if you tighten it too much and strip the bolt. That is why i prefer to do the oil change myself on the crossfire from now on. When you have mechanics working on your car they don't care to do it correctly as much as you do.
Old 09-05-2010 | 07:11 PM
.............. When you have mechanics working on your car they don't care to do it correctly as much as you do.
But I'm sure most of them do not forget to put the washer back on.
I had to say that ..... sorry.
Old 09-05-2010 | 07:26 PM
I would have put it back on if i knew it was there. Just didn't know about it or see it until after i was done.
Old 09-06-2010 | 01:16 PM
Iamfink2's Avatar
The first oil change I did on my car I didn't replace the washer because it fell off and I didn't realize there was one. I put the plug back in the oil pan and never had a leak. I replaced it next time after reading on here about the crush washers so I doubt you would have had a problem. Pat
Old 09-06-2010 | 01:25 PM
32krazy!'s Avatar
this is really a ton of worry over nothing. if you forgot the washer it may seep a bit but not enough to do any damage just may make a mess. if you replaced it with the same washer same results.
at least you didnt drain the oil into my coolant pan LIKE someone else did!!!
Old 09-06-2010 | 02:30 PM
Thirteendog's Avatar
If you wouldn't hide the oil pan somebody wouldn't have to use the coolant pan.
Old 09-06-2010 | 02:38 PM
32krazy!'s Avatar
nothing like hiding it in plain sight!! im thinking you were wearing those rose colored specs you like so much!
Old 09-06-2010 | 02:55 PM
Larry Hitze's Avatar
I've reused the old washer when I didn't have a new one and mine didn't leak at all. I've since kept new ones on hand extra so that I have them though. For the cost of them I just use new now that I have them.
Old 09-06-2010 | 03:25 PM
PNA's Avatar
PNA
Thanks. I will get a new one for next time. But I doubt the dealership replaces them. I appreciate all your help!
Just had the dealer do my oil change last week. Good news - only $59.95 for the oil change. Now you have me wondering if the dealer replaced my washer as well. At least from everyones previous experience, using the older one may not present a problem.
Old 09-06-2010 | 03:34 PM
Man, if I EVER forget the washer, I won't tell a damn soul.....
Old 09-06-2010 | 06:59 PM
Iamfink2's Avatar
For $59.95 I'd be worried if they used Mobile 1 also.
Old 09-06-2010 | 07:27 PM
That is why i am doing my boil changes on the crossfire. I don't trust these dealerships! At least I know it is done right using the right materials.
Old 09-06-2010 | 07:32 PM
32krazy!'s Avatar
washer smasher!! try leaving the magnet out of the tranny pan!! then loosen everything and slip it back in without drooling the fluid all over!! (dont ask how i know this doc!)
Old 09-06-2010 | 08:10 PM
PNA's Avatar
PNA
Believe me, I wondered myself. It's a 5 star dealer, with a trained / qualified Crossfire mechanic. I checked the product code for the filter and it checked out. This is the product code for the Oil - 5127394AA *OIL I wasn't sure either and I did some investigating and it appears to be the proper code for synthetic motor oil. Whether it's 0-40 or 5-30 or not, I'm not sure. I saw a thread on the forum that some specs have changed -- and most important thing is that it's synthetic and either 0-40 or 5-30/40. It doesn't have to be Mobil 1 -- and that others are using suitable alternatives as well. Anyway, it sounded too good to be true to me, but it appears they did what they were supposed to do.
Old 09-06-2010 | 08:37 PM
[QUOTE=PNA]Believe me, I wondered myself. It's a 5 star dealer, with a trained / qualified Crossfire mechanic. I checked the product code for the filter and it checked out. This is the product code for the Oil - 5127394AA *OIL I wasn't sure either and I did some investigating and it appears to be the proper code for synthetic motor oil. Whether it's 0-40 or 5-30 or not, I'm not sure. I saw a thread on the forum that some specs have changed -- and most important thing is that it's synthetic and either 0-40 or 5-30/40. It doesn't have to be Mobil 1 -- and that others are using subtable alternatives as well. Anyway, it sounded too good to be true to me, but it appears they did what they were supposed to do.[/QUOTE
A dealership once charged me 60 dollars. I assumed the woman at the counter made a mistake.... I didn't argue!
Old 09-06-2010 | 08:38 PM
No kidding! Imagine the length of a thread for someone that lost their nuts?
  #38 (permalink)
Old 09-06-2010 | 08:54 PM
I have dropped my nuts before....sometimes they are hard to find....
  #39 (permalink)
Old 09-06-2010 | 11:50 PM
huudoo's Avatar
remember their is a oli check system on the car..
read the manual, it's kinda tricky though
  #40 (permalink)
Old 09-07-2010 | 07:58 PM
Musclefan21's Avatar
I just changed my oil yesterday at autozone parking lot in 15 minutes. I hate replacing those damn rings.. too slippery to get them out easily
Quick Reply: Oil Change Mistake With Pictures! Help...
