! - HOT door handle !
Old 05-29-2010 | 12:06 AM
xodus52's Avatar
Default ! - HOT door handle !
I just got back from a very brief drive and discovered that my door handle on my driver side was especially hot. Almost to the point where it could burn my hand, and it's night time and cool out right now. I'm very worried that this may be an electrical problem or something with the window motor. I have noticed that every once in a while the window on the same side will make a "clunk" sound when rolled down, as if it needed to be opened up and greased. Nothing severe at all though, which is why this is very concerning for me. Has anybody experienced this in the past or have any ideas of what could be the issue? Much appreciated.
Edit: This is the interior door handle and the panel surrounding it is quite warm as well.
Old 05-30-2010 | 11:08 AM
Crossfire725's Avatar
Default Re: ! - HOT door handle !
the only thing i would say is electrical problem. there is nothing really in that door besides a speaker a tweeter and the window motor. speaker is to far away. so check the tweeter and window motor. window motor is prob it. take off the door panel. (u can find a thread on how to do so. ) and then put the window up an down. listen to clicks or like a tripping grounding out electrical sound. feel for heat as well. locate be you ear and the sound where the motor is located. if it makes sound mine as well change it anyway. that should solve it.
Old 05-30-2010 | 11:29 AM
rush549's Avatar
Heated door handle option maybe?
Old 05-30-2010 | 07:55 PM
Are you sure that that side of the car was not heated by the sun? The screws that attach the door handle are screwed into the door body and they could transmit heat from the outside of the car to the inside.
If you look at my pictures there is one of the inside of the door without the door panel in place and the outside face of the door panel as well. The screw attachment points are shown on both.
I cannot see an electrical problem causing this problem without a fuse blowing or a smell.
Old 05-30-2010 | 08:20 PM
maxcichon's Avatar
Unless the motor is not turning off at the limit of its travel?
11-11-2015 05:22 AM
nataliefs
10-05-2015 01:03 PM
Billy22Bob
09-28-2015 08:08 PM
waldig
09-17-2015 10:35 AM
jaesa
09-07-2015 01:50 PM
Quick Reply: ! - HOT door handle !
